Fixing flash programming in DM365 chip within GL300 remote controller
PL
Here you will find not only instructions to blindly follow, but an explanation of what you're really doing. Fixing is also preceded by diagnosis - this is how all repairs should look like.
So, here is the link to my DM365 chip reflashing tutorial, with specific tasks performed on GL300 RC:
Preamble
Electronics is not black magic, and it is not fixed by rituals. Some people are sometimes able to fix their issues by a series of actions they don't really understand, then announce their specific solution as universal cure. This is not how any of this should work. It seem easier and faster, but it is the dark side.
I hope this guide to give readers understanding of what they're doing. Knowledge acquired here can be then used to fix different boards and devices. All digital devices are very similar in how they work.
This guide was made with help from @oemgpsnav.
Problem statement
This instruction concerns the following DJI Remote Controllers:
- Phantom 3 Pro/Advanced, the first release version, GL300a (the "a" at end is important)
- Phantom 3 Pro/Advanced, any version if you have HDMI output on your RC (HMDI output board in an upgrade compatibe with all GL300 RCs)
- Inspire 1 RC (GL658A)
The instruction shows how to diagnose and solve the following issue:
After connecting Mobile Device to the drone via USB-to-microUSB cable, the mobile device does not react on the connection. Mobile device does not find/recognize the RC.
We will assume the issue was verified to be caused by RC (by either trying another RC which worked, or checking different cables and mobile devices with the same issue appearing on all of them).
If you need to diagnose the cause of your issue, do not just assume it's the same as described here; to through the diagnosis graph to find your cause:
Fix no video feed / black screen / no image transmission / no FPV on Ph3 Pro
Preparations
First, remove the Interface Board from the RC. There is an instruction for that from OEM:
How to install HDMI Output Module on Phantom 3 Remote Controller
Check the board from physical damage. You can use a multimeter to check whether USB output pins are connected, and no capacitors are shorted. If there are no indicators of physical damage the issue is probably software-related. To be sure, we need to check whether the chip which controls the board boots properly.
To further diagnose and fix the board, you will need:
- a temperature controlled soldering iron, and enough skill to solder wires to test points on the board
- a USB-to-TTL converter (also known by brand name - FTDI), which supports 3.3V logic (note that if device claims it's "universal" but there's no jumper to switch to 3.3V, then it is crap and will not work)
- ability to use that converter from your PC (if you know what command line tools are or what a text terminal is, you should be ok)
- Good amperage USB output (ie. from a USB hub), or just additional 5V power supply; The USB standard of 500mA is the minimum power the board needs, and any drop below that will cause the chip to fail flashing. So it is better to use USB with high current rating (ie. 1A charging outputs).
The board consists of Texas Instruments DM36x Media Controller chip, and additional chips needed for it to work: RAM chip, NAND chip and voltage regulators. To get more info about this board, look at GL300 Interface board description by OGs. The DM36x is a processor which runs Linux as operating system. We need to hook to it and check whether Linux boots properly.
Soldering to debug serial interface
We have our board out, and USB-to-TTL converter ready. Let's solder cables to the test pads. What is a test pad? Those are the small copper dots on the Printed Circuit Board - they are used during manufacturing to test whether the board works as intended. The pads are named with white paint on most boards; if your board doesn't have the white names, find the test pads location on photos in "GL300 Interface board description" linked above. It is best to solder detachable wires to the board; most USB-to-TTLs have pin outputs on which you slide a cable, so this comes with the package.
To the soldering:
- At back of the Interface Board, you will see test pads marked "GND" and "VCC_5V", close to each other. Solder wires to these (you should be able to solder to any GND pad instead; but the one closest to VCC is the safest choice). Make sure you will be able to easily connect/disconnect the 5V power supply. You will want to be able to reset your power while other pads are all connected.
- Also at back of the Interface Board, you will see test pads marked "UART0_RX" and "UART0_TX" (or "368_RX" and "368_TX", on some boards). Solder wires to these as well.
Now, connect everything:
- GND cable to GND pin of your USB-to-TTL; if you're using external power supply, connect GND to there as well (something may burn if both grounds are not floating; but today we mostly have floating grounds in devices, so it should be ok)
- VCC_5V cable do not connect yet - you will be connecting it to 5V power supply, either from USB or external supply)
- UART0_RX cable to the TX pin of your USB-to-TTL, and UART0_TX cable to the RX pin. Yes, usually we connect RX-TX and TX-RX (R is for Receive and T is for Transmit; if something is transmitting, we want the other side to receive)
- plug your USB-to-TTL converter into a port from your PC; make sure to switch it to 3.3V logic, if it has a jumper for that
You may wonder why we use 3.3V logic, even though we're supplying the board with 5V power. This is because the board is really supplying 3.3V to all the chips - it converts the 5V at input to 3.3V before sending it anywhere further.
After you've connected the USB-to-TTL to your PC, it should've installed the new device. In case of Windows you should've heard a sound queue and the device appearing in "Device Manager" under "Ports", in case of Linux - a device appearing as "/dev/ttyUSB*" and messages about its installation being visible in "dmesg" output.
Connecting to the debug serial interface
Connect to the USB-to-TTL device using a terminal application. For windows, use ExtraPuTTY; for Linux - either minicom or picocom.
Set transmission configuration to 115200 8N1 (baud rate: 115200, data bits: 8, parity: None, stop bits: 1) and connect to the proper serial device (the one which appeared in "Device Manager" or "dmesg"). You should see an empty window, with cursor only.
Everything is ready for a first boot.
Booting the board with debug interface connected
Connect the 5V power pin to start booting the board. What you see on the terminal screen determines the further steps.
Possible cases:
1. Magic Smoke escapes.
If this is what happens, please describe details so we could all have a laugh.. or maybe avoid your mistake.
2. Nothing happens. Still only cursor on screen.
In this case we can't be sure whether the DM36x doesn't print anything (which indicates bootloader damage), or your serial connection is broken somehow.
Your setup, you need to test by yourself. Maybe RX and TX wires are switched? Maybe your USB-to-TTL just doesn't work? It there's no apparent issue, you can just assume it's bootloader damage. While fixing it, you will have another opportunity to test the serial setup.
To fix bootloader damage - go to "Reflashing bootloader" chapter below.
3. The terminal outputs something, but not readable text - just garbage.
This is a clear indication of your serial connection being incorrectly configured. Make sure you use recommended terminal apps. Make sure you've entered transmission params correctly.
The DM36x is sending out text, and something from your setup changes it into garbage. Fix your setup.
4. The terminal outputs many lines of text.
This is what we expect from DM36x if bootloader is able to execute. You now need to analyze the text to figure out if everything boots properly, and if not - at which part it stops.
Go to "Finding issues in logs from terminal" chapter below.
After log are captured, you can disconnect the 5V power. In any of the cases above, you may want to read "Overview of the boot process" chapter below to get an understanding of the whole thing.
Booting of the DaVinci Linux on DM36x consists of the following parts:
1. Bootloader loads and selects a kernel to run
Bootloader is just a short program which prepares grounds for the Operating System to load. On your PC, you have bootloader as well:
- if you're running Windows, it is the place where you can select between "normal boot" and "safe mode", hidden unless ther's an issue
- if you're running Linux, you probably see GRUB menu at startup, where you can select older version of kernel to start; though there are many bootloades to choose from
The DaVinci Linux uses U-Boot as its bootloader.
2. Kernel starts, initializes drivers for available hardware components
The messages from kernel are easy to spot, as they're preceded by time marking in square brackets, ie. [ 0.123456].
3. Kernel mounts root filesystem
This is technically part of kernel startup, but good to separate as a possible point of failure. Until this point, the kernel had no access to any additional files.
Now it prepares the mechanism to access files within the system - "mounts" one of the partitons are root filesystem. Root filesystem is the base for accessing everything within UNIX compliant systems like Linux - not only normal files and folders, but also devices and processes. The partition is using UBI File System.
4. Application which decodes and routes data and video between the RC and Mobile Device starts.
A few last lines of the booting process is just loading the application which connects to Cypress 68013 chip within the RC, and acts as USB Master for the Mobile Device.
The first question we need to ask is whether U-Boot is working properly. This is easy to check, as the main function of bootloader is to load kernel - so if it is trying to load kernel, it is working.
And how do we know whether it tries to load kernel? Easy - if it does, it will print the line:
Code:
Loading from nand0, offset 0x??????
The place where question marks are will contain offset from which the kernel is tried; we're not interested in these yet. As long as a line like above exists in logs, bootloader is working correctly.
If there's no such line, then you need to reflash bootloader. Go to "Reflashing bootloader" chapter below.
For reference, here are all the messages a bootloader has shown on a specific, fully working board:
Code:
DM36x initialization passed!
UBL Product Vesion : DJI-486M-UBL-1.0-rc0(2015-10-30)
Dji UBL Version: 1.51(Nov  2 2015 - 15:46:28)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
   DONE
Jumping to entry point at 0x81080000.
U-Boot Product Vesion : DJI-DEC-Uboot-1.0-rc0(2015-11-02)
U-Boot 2010.12-rc2-svn3214-Dji (Nov 02 2015 - 19:39:56)
Cores: ARM 486 MHz
DDR:   360 MHz
I2C:   ready
DRAM:  128 MiB
NAND:  128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net:   Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
   Image Name:   Linux-2.6.32.17-davinci1
   Created:      2015-06-23   9:37:05 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4065664 Bytes = 3.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Booting kernel from Legacy Image at 80700000 ...
   Loading Kernel Image ... OK
OK
Starting kernel ...
Note that Bad block table found in the log above doesn't mean anything wrong. It just shows the place where tables which store bad blocks are located.
So the bootlader is trying to load kernel. Now let's make sure it is succeeding in the loading. If it does, then the bootloader work should end with Starting kernel ... as above. But wait! There are two copies of the kernel stored, and only one of these is proper, working kernel. The other is a recovery kernel, used to make it easier to fix stuff in case primary kernel dies. This recovery kernel can't correctly connect to the Mobile Device.
To be sure a primary kernel is being loaded, make sure you don't see the following lines in your logs:
Code:
ERROR: can't get kernel image!
Primary kernel resides at offset 0x4a0000 in the NAND memory, and recovery kernel sits at 0x900000. It is possible to have both kernel copies damaged - in that case, you will see can't get kernel image! two times, and booting will stop. If at least one kernel is valid, the bootloader will use it and continue booting.
For reference, here are the messages a bootloader shows for a board which has both copies of the kernel damaged:
Code:
** Unknown image type
Wrong Image Format for bootm command
Loading from nand0, offset 0x900000
Dji-Pro #
If any of the kernel copies is damaged, go to "Reflashing kernel" chapter below. If primary kernel starts booting proerly, let's look further into the logs.
The next possible point of failure is encryption initializaton. There is a small encrypted partition within the NAND memory, and it is required for the encryption to initialize.
If that area is damaged, booting will stop(freeze forever) some time after the message:
Code:
[    ?.??????] encrypt device:atsha204 found
Sometimes the message might also be encrypt device:at88 found. Atmel AT88 is an older version of the ATSHA204 chip; GL300 remotes only use ATSHA204, but older drivers show both chips as AT88; it doesn't really matter which one is shown.
What matters is - if the booting freeze at some and no more messages are logged, and within the last 20 lines there's the encrypt device message, then encrypted partition is probably damaged.
In such case, go to "Reflashing encrypted partition" chapter below.
The next important part of booting is mounting the root filesystem. This happens soon after NAND device initialization, started by NAND device type announcement. It looks similar to lines below, though details may vary - DJI uses various NAND chips from several manufacturers:
Code:
[    0.570000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[    0.580000] Creating 4 MTD partitions on "davinci_nand.0":
If at some point after that message you see UBI error like:
Code:
[    0.800000] UBI error: ubi_io_read: error -74 while reading 512 bytes from PEB ???:2048, read 512 bytes
Or no filesystem was recognized at all with No filesystem could mount root message, like:
Code:
[    1.240000] No filesystem could mount root, tried:  cramfs vfat msdos
Then your root filesystem is probably damaged. The booting in such case will usually end with messages:
Code:
[    1.250000] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
[    1.260000] Rebooting in 1 seconds..
But sometimes it will continue to spew hundereds of UBI error instead.
Go to "Reflashing root filesystem" chapter below if any of this happens.
Now, we've discussed many issues, but what if the device booted properly and is working as intended? How to recognize that?
Well in that case, the chip will continue to print messages after it's booted, at circa one second intervals. The messages may be:
Code:
DummyRead68013 0.000000kb
or:
Code:
read 68013  return size = 0
0kbps
If the messages above are not shown, but what you see doesn't match any of the described cases - you will have to ask someone proficient with Linux for help.
Before jumping to the chapter which described your issue, be sure to read "Downloading images and tools" below to get all the things you need to reflash.
In case you'll be be flashing bootloader, you will need Serial Flasher Host Program from Texas Instruments.
Original releases of this tool are at Arago Project Releases. They were linked to at, now defuc, DaVinci GIT Linux Kernel Releases page. The latest release which still supports the DM36x line is davinci-psp_03.01.01.39. Inside, there is board-utils-davinci.tar.gz which contain the file you seek - sfh_DM36x.exe.
You will also need the images to flash. They are listed on the wiki page with structure of DaVinci firmware; let's list them directly here:
- ubl?.img - stores U-Boot init code; first code which is being loaded while the board starts
- u-boot.img - U-Boot main (application) part; contains most of the bootloader
- uImage - the Primary Linux Kernel, normally used for booting
- uImage_recovery - the Linux Kernel which is used when primary kernel gets corrupted
- dm365_secret.bin - Encrypted partition for ATSHA204 initialization
- ubifs-partition.ubi - Linux Root Filesystem, using UbiFS
These are all the files you might need (though usually only one specific partition gets corrupted, so you only need one for your fix).
Where to get them:
- ubl?.img, u-boot.img and uImage are included in every firmware update, and can be extracted from there. I already did that and you can download them in this archive: View attachment 111454. There are files for different firmware versions inside; use the one closest to the version you have on your RC; or just latest one, if you're unsure.
- uImage_recovery can be downloaded from the OGs Wiki, though I would advise to just use a copy of uImage instead.
- dm365_secret.bin is really unique for every machine and can't be just downloaded; but if it prevents you from booting, it is damaged anyway; you can download a version which shouldn't prevent booting at the OGs Wiki.
- ubifs-partition.ubi is a big partition, and most complicated one to fix; it also contains some machine-specific files, so don't reflash it unless it really is damaged; The OGs Wiki has a link to it, too.
To re-flash bootloader, you first need to force the chip into serial programming mode. This will make the chip ignore content of NAND memory, and instead wait for commands on serial interface. To enter serial programming mode, solder the Boot Select service pad BTSEL to 3.3V pad.
After the pads are shorted, connect the board to PC via USB-to-TTL, as before, and run PuTTY. When you connect 5V power to the board, you should see repeating BOOTME messages on the terminal.
If you don't see them, something is wrong and you need to fix your setup. Find a way to test whether your USB-to-TTL works, check if all your connections look good and verify shorts with a multimeter. If everything seem OK and there is still no BOOTME, then your Interface Board probably is physically damaged - either power supply, or the chip itself, is fried. This can only be fixed by a technician using component level repair.
But usually you will be able to get BOOTME to show. And that means the chip is now waiting for commands from PC. Since we don't know how to type the commands by hand, we will use a tool which will do that for us - sfh_DM36x.exe.
Copy sfh_DM36x.exe, u-boot_prop.img and ubl1_prop.img to a directory with short path, for example C:\tmp on Windows. Open shell window in that folder. Close PuTTY. Execute the command below in the shell:
Code:
sfh_DM36x -nandflash -v -p "COM4" ubl1_prop.img u-boot_prop.img
The tool will show you messages sent by the board in lines starting with Target:. You've seen the initial message in PuTTY, so you should have already figured out you should see Target: BOOTME first. Then the tool will start talking to the board, and you will see a series of various messages.
For a complete log, see u-boot flashing instructions at OGs Wiki.
If everything went well, the final message will be:
Code:
Operation completed successfully.
If instead you see an error:
1. Make sure you've typed correct port
2. Make sure the path to execution folder is short, and all files have privileges to be read by everyone
3. Make sure your 5V power provides enough amperage for the board
4. Make sure cables connecting serial interface are short and good quality, and nothing near them generates interference
5. Read the error message carefully and draw conclusions from it; you may try googling it as well
It is possible that the NAND chip is completely damaged and just won't accept programming, but it is a rare case. Usually errors are caused by not following the instructions exactly.
After bootloader is re-flashed, disconnect the BTSEL pad and get back to chapter "Finding issues in logs from terminal" to verify whether the whole boot succeeds.
Reflashing kernel
So either your primary or recovery kernel got damaged, and you want to re-flash it. Since you have a working bootloader, we can use it to do the flashing. Bootloaders usually have a simplistic shell which allows executing some basic commands without operating system. U-boot is bo exception.
You've probably already noticed that after you connect the 5V power to your board with ExtraPuTTY connected, the first thing you see is Press ESC to abort autoboot. Do that - press ESC. Instead of trying to boot kernel, U-boot will then drop to its shell:
Code:
Dji-Pro #
If you pressed ESC more than once, you may want to remove the additional stokes from buffer by just pressing Enter.
Now, we need a way to transfer our kernel file to the board. For that, we will use part of the RAM connected to the chip. We will first transfer the kernel to RAM, and from there, write it to NAND.
Let's select RAM address 0x80008000. First, we need to clean it from garbage data:
Code:
mw.b 0x80008000 0xFF 0x460000
Now, we can transfer the kernel there. Command for initiating the transfer is:
Code:
loady 0x80008000 115200
The u-boot will answer with Ready for binary (ymodem) download message. Now, we have to use menus of ExtraPuTTY; click File Transfer -> Ymodem -> Send and select the file.
The transfer shouldn't last more than 15 minutes. After it finishes, summary will de displayed, ending with:
Code:
## Total Size      = 0x003e09c0 = 4065728 Bytes
Dji-Pro #
If there is a failure information instead, retry the transfer. If issues continue, use shorter and better quality wires between the board and USB-to-TTL device.
After the transfer succeeds, it is time to write the new kernel to NAND array. Such arrays need to be erased before writing. Then you can save the data from RAM into it.
Note that the commands below modify content of the NAND according to parameters. Do not make a mistake when copying them, or you will damage the NAND programming even more!
If you're writing Primary Kernel, use the commands:
Code:
nand erase 0x04a0000 0x460000
nand write 0x80008000 0x04a0000 0x460000
If you're writing Recovery Kernel as well, follow that with these commands:
Code:
nand erase 0x0900000 0x460000
nand write 0x80008000 0x0900000 0x460000
Remember that if you reboot the board, your kernel is no longer in RAM - so you must repeat the whole transfer, not only NAND write commands.
If the NAND Write fails, make sure your board is powered with high enough amperage, and re-try a few times. The NAND is unusable only if writing both Primary and Recovery kernel fails - you really only need one.
After the kernel is re-flashed, reboot the board and get back to chapter "Finding issues in logs from terminal" to verify whether the whole boot succeeds.
The need to re-flash the encrypted partition is a rare case and I won't be describing it in detail. For instructions, see encrypted partition flashing instructions at OGs Wiki.
Usually UbiFS can fix any arrors within its structure, so I won't be describing re-flashing it in detail. For instructions, see root filesystem flashing instructions at OGs Wiki.
The end
That concludes the guide. Hopefully you have a working mobile phone link on your GL300 remote controller now.
Another outstanding contribution. Thanks!
Reactions: Mark The Droner
Thank you @quaddamage !!
Mine works fine now:)
For me, the hardest was:
Code:
Dji-Pro #
In the Re-flashing primary kernel procedure. :p
Great tutorial and thanks for the zip unencrypted images.
Just 1 thing you forget:
In the Re-flashing bootloader Chapter:
Code:
Code:
In fact, we have to type the command twice.
1st command typed
wait until an infinity message (sorry, i don't remember whats was wrote)
Type:
Code:
Ctrl+C
Then, type a 2nd time: sfh_DM36x -nandflash -v -p "COM4" ubl1_prop.img u-boot_prop.img
Thats'all!
Thanks Again
Reactions: quaddamage
Hi... what an excellent write up ...:)
Assume it’s not relevant for GL300B - for which I have this issue following a firmware upgrade :mad:
@quaddamage , thanks a lot for this. How about similiar problem for gl300b and c? DM365 has been moved onto RC mainboard?
Cheers,
Łukasz
Nope. It has been removed completely, and a faster USB controller (Cypress) is used instead. You connect the mobile device directly to Cypress.
That was actually the original idea, DM365 must have been added to the design as a workaround, due to some issues with the slower Cypress. DM365s transcoding power is only used by the boards with HDMI out, on the normal GL300a interface board the chip just sits there, transferring input to output. It actually uses the exact same firmware you use for HDMI board - so if you somehow was able to tap to the HDMI Out pins from underneath and connect them somewhere, it would start transcoding.
Do does it mean that in case I have gl300b and gl300c rc, and there is no reaction upon hooking up mobile with USB cable except charging, Cypress modules are faulty in both of them? This is my case. Are they replaceable? Need specific programming?
I found the second paragraph of your reply a bit difficult to understand ;)
I don't know what is the issue with your equipment. You have to diagnose it.
I also don't know what are the symptoms of Cypress not booting.
Cypress modules [..] Are they replaceable? Need specific programming?
They do have a small, 51-like microcontroller, which has some minimal programming.
It is included in FW updates.
Datasheets for Cypress chips are public.
Then again, you need to diagnose the circuit before starting the repair.
The gist is - DM365 is not really doing much in GL300a. It just copies video from input to output.
Hey Guys, Is there anyone that can help me with this? I can't get it through my thick head. I got it all hooked up and I can see that my boot image is missing, having a problem understanding what I need to flash it. Thanks for your time and help.
src72
