I regularly descend at 4m/s down to 50ft then at 2m/s below that.It makes funny whirring noises with fast decent. I do ensure I don't have left stick at full limit so as not to trigger prop switch off.
extrememc said:Could this possible be the answer to no more flyaway and the need for a GPS unit?
dbolner said:Will this firmware upgrade to the p2z fix the fly away issue all together as far as mechanical issues go
ianwood said:extrememc said:Could this possible be the answer to no more flyaway and the need for a GPS unit?
Not sure which flyaways you guys are referring to. There are definitely flyaways where they took off from a moving surface like a boat. And there are ones where they calibrated their compass on a sidewalk or in a parking lot. And then there's the one where the owner broke the tip of a blade and taped it back together.
I think the number of unexplained P2 flyaways can be counted on one hand.
Not quite as simple as that. If you descend in GPs mode while there's a nice breeze then even though you don't give any horizontal stick because of that Position Hold thingy the wind speed effectively makes your bird move horizontally through the air which reduces the chance of entering VRS. This effect is absent when in Atti because then you drift with any wind there might be.hook3m said:PetePerrim said:hook3m said:In the new firmware.... "The maximum descending speed is limited to 3m/s." Never paid a attention to it before but what could you achieve before at full down stick?
You could achieve an uncontrolled plummet where gravity took over the descent and you ended up hitting the ground with an impressive 'bang' and a mangled gimbal. Speaking from experience here!! :roll:
Maybe in Att. mode but not in GPS. I've been 1000 ft and did a full stick down until about 200 ft. with no issues and full control. If you $#% up your Phantom it straight up Pilot error.
BigBadFun said:Is it possible to keep this thread about the firmware update and not taking off from boats or descent speed preferences... ta![]()
extrememc said:So you saying since I calibrated mine in my drive way it could fly away?
iResq said:And taking of from a boat causes fly aways? Weird.
ianwood said:No one can download it yet. That can only be repeated so many times. Maybe we can talk about what we think it will be like. I think the new firmware will give me 25 minutes of flying time, will automatically avoid power lines and tree limbs and will have a new flight control algorithm that eliminates yaw wiggle in 40MPH winds so I don't need to bother getting a 3D gimbal!
Quadro said:Seriously, though, could have used that ability to fly in 40MPH winds today. It was a steady 30+MPH with gusts into the 50s.
ianwood said:extrememc said:So you saying since I calibrated mine in my drive way it could fly away?
Yes. If there is anything magnetic nearby (e.g. rebar under a paved surface) you risk a flyaway. Maybe the new firmware calibration algorithm helps to detect it better but do not calibrate in an area that may be influenced by nearby magnetic material.
Yes. IMU initialization requires the Phantom is still when you turn it on. If it is not still, like on a boat, the IMU will either fail to initialize and the Phantom won't start or worse it will think it initialized OK but was moving enough to get erroneous data that will then put it at risk of a flyway.
BigBadFun said:WHAT A PILE OF CRAP. Toilet bowling probably worse than ever. J-Hooking still exists.
Totally defective product. DJI - WTF are you doing??????????????????????????????????? Not happy.
