Feiyutech Mini 3D pRO 3 Axis Gimbal (Wireing)
Just picked up the Feiyutech Mini 3D pRO 3 Axis Gimbal. Need some help figuring out how to wire the gimbal to the Phantom. I have a Phantom Vision 2. I'm a novice so the greater the detail the better, appreciate your help. A picture of the wiring harness is included, if you can tell me where each lead goes especially the power lead. (how to get power to the gimbal).
I soldered a male 2 pin jst to the board for power supply. For pitch control you plug the blue wire into F2, use the bottom pin. Providing you have the gimbal pitch lever on the back of your remote (you can buy on ebay or amazon) all you need to do is calibrate your transmitter and you should be good to go. Although I'm sure you have solved this by now.
Hi guys,
I just got given a Phantom 2 Vision + for free, so I wanna make the most of it. There's nothing like a free meal, right??
I already have a feiyutech that I was using on another drone, and like you I'd like to put it on the Phantom.
My questions are around 2 things:
1. What carbon/metal plate to you recommend to fit the gimbal underneath the Phantom?
2. Regarding video transmission... How and where do you plug the yellow and black cable?
Cheers!
Romain
dlr11164
