Meta4
Premium Pilot
- Joined
- Jan 8, 2014
- Messages
- 15,306
- Reaction score
- 9,247
None of the things you mention are at all likely to cause problems for flying over.however the other thing we haven't talked about is wifi interference, maybe that also placed a part, the place I was shooting had Xfinity in the living room about 25ft away. Looking back at the images I took from out front I also noticed a metal roof on the add on back porch structure, couldn't see it from the ground. As for interference there was plenty, metal roof close by approx 5ft behind me, screened in porch with aluminum support structure, concrete dock with rebar, and boat lift on dock approx 20ft away, plus electrical on dock, kind of a perfect storm
The steel roofs would be a problem if you tried to launch from up on them, same for steel girders.
But you could fly withing 3 or 4 feet of them without any issue at all.
The electronic might cause a little wifi interference that might reduce your signal strength marginally while you were close by, but disappear as you moved away.
In extreme cases it might (at worst), swamp your signal and initiate RTH.
You haven't mentioned anything that I would expect to cause any problems
I can't see any reason why you shouldn't be able to fly there again tomorrow without any problems either.I've shot many over the years without issue until the other day so I never gave it a second thought.
Are you certain of that?even though my home point was established it didn't hold.
It would be exceptionally unlikely for your home point to change unless you physically changed it.
Your flight data would confirm whether there was any change in your home point and I'm pretty sure it would show no change at all.
A flight test at the park is a good idea, but there shouldn't be any need to recalibrate anything.I thought about pursuing the problem, doing a re-calibration at a park close by and a test flight
The drone would tell you if there was anyway.
Your drone will be just fine.not being able to power it down through multiple options, motors now possibly damaged due to 20 mins of high rpm's, plus the motherboard that malfunctioned on an earlier model, parts can become defective or outlive their life expectancy, not sure its worth the risk, rather be safe then sorry and spend the money on a new one then have a huge lawsuit against me in the event of a mishap. Love the product and looking at the newest one (Phantom 4 Pro+), I could use my same batteries, minus the one that overheated of course, again safety. I could use a tax deduction this year and I rather error on the side of caution.
The motors last for years without maintenance and are made to run fast.
That's what they do in a normal flight.
Your battery is probably fine too.
It's normal for them to be hot when the drone is flying fast.
Try switching the drone on and off, using the same battery from that day and see if it's OK when you aren't distracted by everything that was going on then.
Then go to the park and do a little test flying.
But first, it would probably be good for your confidence to have someone look at that flight data.
Go to DJI Flight Log Viewer | Phantom Help
That will give you a summary report of the flight data.
Come back and post a link to the report it gives you and I'll analyse it and come back and show you what it says.
