Downgrade IOS APPS ( how to ) step by step!
Sarasota, FL. USA!
Hello Everyone,
Here is some info I compiled, for those of you experiencing " PROBLEMS " after updating a DJI IOS app, to your smart device!
This is a step by step " HOW-TO " downgrade ANY iOS app , through ITUNES, using Charles Proxy " Web Debugger ".
You'll first need to download Charles!
Go to:
Charlesproxy.com
Download the FREE 30 day trial, ( just uninstall when finished )
Ok
Here is the video on how to do this:
Ok
Now I've compiled the numbers and placed them with APP versions and dates for you: ( you can search the app in iTunes, and search versions, and what each version has or has added ) too much typing for me, but this will help:
Ok. ( DJI VISION APP )
Use this number for this version:
15770051 ver. 1.0.19 ( July 19, 2013 )
23233090 ver. 1.0.22 ( Sep.20,2013 )
72532642 ver.1.0.27 ( Oct.08,2013 )
88632642 ver.1.0.28 (Nov.07,2013 )
176052660 ver.1.0.30 ( Dec.01,2013 )
289042895 ver.1.0.31 ( Jan.11,2014 )
300442650 ver.1.0.32 ( Jan.14,2014 )
519392631 ver.1.0.37 ( Apr.07,2014 )
585422641 ver.1.0.41 ( June24,2014 )
596284901 ver.1.0.41 revision " B "
642542793 ver.1.0.42 (July29,2014 )
706673865 ver.1.0.43 (Oct.28,2014 )
811174353 ver.1.0.46 ( Jan.23,2015 )
811505240 ver 1.0.46 revision " B "
811660004 ver.1.0.48 ( Feb.06,2015 )
813236208 ver.1.0.52 ( Sep.09,2015 )
813583643 ver.1.0.53 ( Oct.08,2015 )
814227950 ver.1.0.54 ( Nov.12,2015 )
814272310 ver 1.0.54 revision " B "
814418297 ver.1.0.54 revision " C "
815541257 ver.1.0.56 ( Jan.14,2016 )
815587449 ver.1.0.56 revision " B "
815735194 ver.1.0.56 revision " C "
Ok ( DJI GO APP )
810766904 ver.1.0 ( Feb.11,2015 )
811778986 ver.1.0.1 ( Feb.13,2015 )
811816666 ver.1.0.2 ( Feb.26,2015 )
812042400 ver.1.0.3 ( Apr.02,2015 )
812332348 ver.1.1.1 ( May05,2015 )
812459200 ver.1.1.2 ( May27,2015 )
812643015 ver.1.2.0 ( June26,2015 )
812940093 ver.2.0.0 ( Aug04,2015 )
812752484 ver.2.0.0 revision " B "
813037514 ver.2.1.0 ( Aug13,2015 )
813098150 ver.2.2.0 ( Sep07,2015 )
813521419 ver.2.3.0 ( Oct05,2015 )
813523578 ver.2.3.0 revision " B "
813665930 ver.2.3.0 revision " C "
813502052 ver.2.3.0 revision " D "
813321065 ver.2.3.0 revision " E "
813856913 ver.2.4.0 ( Oct21,2015 )
813919876 ver.2.4.0 revision " B "
813848230 ver.2.4.0 revision " C "
813876776 ver.2.4.0 revision " D "
814414870 ver.2.4.1 ( Nov16,2015 )
814445173 ver.2.4.1 revision " B "
814493632 ver.2.4.1 revision " C "
814584509 ver.2.4.2 ( Nov25,2015 )
814566170 ver.2.4.2 revision " B "
814760906 ver.2.4.2 revision " C "
815084483 ver.2.4.3 ( Dec18,2015 )
815086904 ver.2.4.3 revision " B "
815112170 ver.2.4.3 revision " C "
815288287 ver.2.4.3 revision " D "
815611197 ver.2.5.0 ( Jan10,2016 )
815615585 ver.2.5.0 revision " B "
815764145 ver.2.5.0 revision " C "
815878759 ver.2.5.1 ( Jan15,2016 )
815949783 ver.2.5.1 revision " B "
815876501 ver.2.5.1 revision " C "
816265475 ver.2.6.0 ( Feb02,2016 )
816232239 ver.2.6.0 revision " B "
816249216 ver.2.6.0 revision " C "
816547767 ver.2.7.0 ( Mar13,2016 )
816751249 ver.2.7.1 ( Mar15,2016 )
816962519 ver.2.7.2 ( Apr13,2016 )
817118268 ver.2.8.0 ( Apr25,2016 )
817278603 ver.2.8.1 ( May09,2016 )
817508323 ver.2.8.2 ( May25,2016 )
817522546 ver.2.8.2 revision " B "
Ok hope this helps!
J Dot
:cool:
Take Care, Fly Safe!
Holy cow! Believe it or not, it's actually EASIER to jailbreak and use AppAdmin than follow this.
Hello Everyone,
Go to:
Charlesproxy.com
Ok
Ok
Ok ( DJI GO APP )
Ok hope this helps!
J Dot
:cool:
I tried your technique. The Charles Proxy program doesn't work... doesn't record anything. Plus, my internet is so fast, I have about 5 seconds to pause the download. I don't have the option to highlight and delete, I can only pause the download. I'm on a Mac. Any suggestions?
Maybe try to get with someone with another PC and try .
Welcome to the forum glen :)
Update:
Must use Charles proxy version 3.0 or older, they changed some stuff in the newer version, not letting you view things through word pad, and changed scripts in some areas, so newer version than 3.0 is different and will not work. But just tried version 3.0.2 I believe and it worked, so 3.0 or older should be same as the video above, looks hard, but quite easy.
J Dot
:cool:
Reactions: dirkclod
I have had no luck with Charles. . . tried various versions and it keeps taking back to their home page for the latest up dates. Or using other sites. . . I get a screen that tells me I can't download this to my win 10.
Hey Tony,
I've not messed with Windows 10?
I'm on Windows 7. I found the new version Charles does not work, only v3 and before. Do you possibly have a relative, of buddy, with a Windows 7 or earlier laptop you can use?
Please let me know, and I'll ask my uncle about windows 10, and Charles.,
J Dot
:cool:
Is there a newer version that has been documented to be the last version before the app broke for most people? Why do you download the original version? Does that mean that you have to go through this, trying each successive update until you find the one that is newest but still works?
Johnboy94
