DJI Launches New Era of Intelligent Flying Cameras
The Phantom 4 boasts sweeping curves, elegant lines and a polished shell that redefines the classic Phantom 4 shape. Its exquisite detailing and matt finish composite components add a level of finish and quality never seen before in a flying camera.
Fly with Tap
Flying is easy for everyone. Double tap the screen to fly. An Obstacle Sensing System keeps the Phantom safe as it goes, and Smart Return Home returns it to you more safely.
Visual Tracking
ActiveTrack lets you track a subject automatically, no band or beacon required, with obstacle avoidance keeping the Phantom clear of objects. Moving POI lets everyone shoot previously impossible shots.
Extended Flight Time
Advanced propulsion systems, highly integrated and more streamlined design combined with a larger capacity battery gives the new Phantom 25% more effective flying time.
Sport Mode
A brand new Sport mode brings responsive controls and the thrill of speed everywhere. An integrated gimbal and new battery positioned to move the center of gravity close to the aircraft’s core combines with raised motors that increase torque reaction, and a reliable flight control system which precisely controls the aircraft’s movement to make flight at high speeds safer.
Advanced Aerodynamics and Stability
The Phantom 4’s sleek, streamlined and highly integrated form minimizes buffeting when flying in strong winds and against gusts from any angle, keeping its movements predictable and precise. A tightly integrated gimbal lifts the center of gravity close to the core, boosting its stability even further.
Multiple Flight Modes
The Phantom 4 is flexible enough to meet different flying demands. In Position mode you can use satellite and Vision Positioning, TapFly, ActiveTrack and Intelligent Flight Modes. Sport mode adds extra agility and speed, reaching 45mph (72kph) while maintaining satellite and Vision Positioning systems. Atti holds the Phantom’s altitude and level but switches off satellite positioning making it ideal for smooth film making movements.
Sense and Avoid
We all use our eyes to see and interact with the world. A forward Obstacle Sensing System gives the Phantom 4 it its own pair of eyes, empowering it to see in three dimensions and to react. In Normal Mode if it sees an obstacle coming close it will stop and hover. In TapFly, ActiveTrack and Smart Return Home modes it will avoid the obstacle, or hover to avoid a collision. It also gives you warnings so you always know what is happening to the Phantom. The downward facing Vision Positioning module contains dual cameras and dual ultrasonic sensors to offer five times more positioning accuracy than previous systems. Used indoors, it provides a GPS-like flying experience, giving you the confidence you need to fly indoors.
High Performance Camera
Capture moments that will last a lifetime or take aerial film making to a higher level with the powerful Phantom 4 camera, featuring 4K video capture at 30 frames per second and full HD 1080p at 120 frames per second for smooth slow motion. An aspeherical lens with a 94° field of view (FOV) reduces distortion by 36% and chromatic aberration by 56% when compared to a Phantom 3. A reduced hyperfocal length of one meter allows you to get closer to objects while keeping them in pin-sharp focus.
Professional Post Production
A total of 10 color profiles are available to give you the look you need or the image data you want. These range from a Vivid mode that amplifies color and contrast to create videos that look incredible without extra processing, to Cine-D and D-Log modes offering high dynamic range footage for professionals, providing the best color space for post-production. The power to edit is also essential for professional photography, so the Phantom 4 boasts not just 12 megapixel photos but also Adobe DNG RAW support as well as lens profiles built straight into to Adobe Lightroom and Photoshop.
Integrated Gimbal
The Phantom 4’s camera is equipped with the latest in camera stabilization systems. Featuring a specially designed u-frame structure that provides better stabilization. Its movements are controlled by a Gimbal Control Unit that is in constant communication with both the gimbal’s Inertial Measurement Unit and the Phantom 4’s flight controller so that it can prepare for the Phantom 4’s movements before they happen. This gimbal is accurate to a highly precise ±0.03°, coupled with custom designed dampers, the gimbal ensures smooth footage.
Intelligent Flight Positioning
The Phantom 4 draws on up to 24 satellites to give you more accuracy and a faster connection to satellites, keeping you in complete control of your flight. Using a combination of GPS and GLONASS it is completely aware of its starting point and location and relation to you during flight. This intelligence means it knows its last position, provides return to home, shows you where it is on a map and much more.
Built-in Redundancies
On rare occasions, inconsistencies in compass or IMU data can affect the way an aircraft behaves. The Phantom 4 features dual compass modules and dual Inertial Measurement Units (IMUs) that allow it to constantly compare the data it is receiving through both pairs. This data is run through advanced algorithms to check accuracy and any inaccurate data is simply discarded without affecting flight.
Learn More
Reactions: QuadBart
I didn't see better customer service on the list
Lol... Didn't see anything about parts availability... Or spare batteries available when the P4 ships...
I'm keeping my P3P.
src72
