Never needed to use it but have a battery bank and like you said just Velcro it under the TX and plug it in the charging port and is way good enough. Can charge up my Mini if necessary alsoI havent seen anything about a remote battery mod. when i had the p3s, i was getting a solid amount of flights per charge.
Im pretty sure its just a lipo battery . Probably could get one with more mAh but I have no idea what would be compatible.
Maybe use a portable usb battery pack to connect to the bottom of the remote instead of switching out the battery itself?
Okay if I buy this for my P3S will it go really far and only have to worry about battery life ? Im just scared If i invest 200$ into this and it will only just go a little farther can someone explain this whole thing in alot of detail like whats the range i should expect thanks
That's right you don't know and if you avoid the Standard like the plague why do you keep posting in this section .@secret, the DBS mod for P3S will double the range. I don't know the specific range of P3S but since it comes without light bridge and relays over a built in wifi transmit and receive... So I expect the P3S gets around quarter mile range and you might be able to go a mile or two with the upgrade. But again I avoid the standard like the plague. The advanced and pro can get around 6 miles with the DBS mod.
I can dig it. You won't be disappointed. Antenna mod is the best upgrade you can do.It just a Christmas present and I'm trying to take full advantage of it.
YepSorry Dirk I didn't realize I was in the wrong section. But I did read the DBS does increase the range of P3S about double its stock range. The stock range is 1km. So your range with DBS P3S mod with out amps is going to be around 2km in optimal conditions.
Nice handStandard without mod 5700 feet
Standard with mod 9066 feet
5.8's are herehttp://www.phantompilots.com/media/d6096823-cf40-43b1-989f-318d8ff8e562_zpsoi90jaav.832/
What picture ya want to see .
Since we are on the topic, how do you correctly position those dipoles to get the optimal signal?Not cheap and did try cheap ones but these worked the best .
Is really not that hard if you have been going in P2's like I have bro.
Hardest part for me on this one was those clips holding the shell together but don't have to worry with them no more .
And I know what ya mean about the NFZ stuff . I'm lucky where I live .
