- Joined
- May 13, 2018
- Messages
- 139
- Reaction score
- 39
- Age
- 79
Flying a Map Pilot Pro 2-battery mapping mission with P4P. Initial take off, I got a message I'd never seen before " “check_2100_flight_count_need_cali / dji_check_fc_takeoff_failed_unknown_error”. Everything was responding right and all the screen telemetry looked good, so proceeded with the mission without further issue. Manually initiated battery swap after 20 minutes. Got the same warning message on 2nd launch, again proceeded with the flight with everything otherwise looking good. Four minutes into the flight lost connection and subsequently found the drone crashed/destroyed.
Just now downloaded the CSV files from the iPad for the two flights. First flight shows the above failure message several times during the flight. The 2nd flight (crash flight) CSV file shows that error message several times followed at ~4 minutes into the flight with these failure notes in the CSV record. That crash flight CSV is attached.
Note that there was continued normal battery voltage for several more lines after these log entries. Then the CSV entries just ended, undoubtedly when it crashed. I had to convert the CSV file to a pdf in order to get the forum web site to upload it.
This looks to me like a flight controller failure, but I'm not familiar with these messages. Any comments/suggestions are welcome. Thanks........... Bob R.
dji_check_center_Gimbal_disconnected | |
dji_check_center_Camera_disconnected / dji_check_center_Gimbal_disconnected / dji_check_center_mc_connection_reason / dji_check _product_not_connect_aircraft_reason
