If you just Google how to calibrat the phantom videos will pop up step by step let us know how it works out....Hi all, can someone please help me and post calibration step by step for phantom 1, I tried but green and red light on computer not on, phantom and computer won’t talk to each other. Thanks
This should have everything you need to set up your NAZA-M V2 controller . This is the controller P1 uses .Hi all, can someone please help me and post calibration step by step for phantom 1, I tried but green and red light on computer not on, phantom and computer won’t talk to each other. Thanks
In this case my phantom is P330, what should i do?Make sure you phantom is the 1.1.1 not the 330 model
Naza-M V2 - Downloads - Manuals, Software, Drivers download | DJI
Naza-M V2 is a lightweight all-in-one multi-axis control platform with independent PMU and amazing function extension.www.dji.com
And a diagram down below that the other man posted is what I'm talkin about flipped the switch up and down seven times and then rotate the Drone like it shows in the pictures belowYou might not want to update the software on the Phantom one because it's so old it's not going to probably fly with all you need to do is Flip Your F2 switch seven times up and down to and then rotate the Drone connect to the satellites calibrate it to the compass on your remote
Can you tell me more about the differences on phantom 1.1.1 and p330?Hope this will help.
First phantom is the p330 is the regular naza that is red the 1.1.1 has naza m v2 witch is yellow and it has self tightening props 2 reciever antennas sticking out of the legs if you go on YouTube. Com and search naza m v2 light patterns all your answers will be answered and let us know how it goes and what you figured out...Good luck
Okay then you need an old computer that has Windows 98 anything newer than 98 you cannot use will not connect your drone to the computerHi, I already did the compass calibration but still can’t fly, just sit there with 2 green blinking lights.
Is there any other options beside window98?
Thank you, i will let you know
You can try the MacBook I never have make sure your satellite your compass aside your drone is plugged into the board because that won't let him take off neither and are you sure all your connections are plugged in the right spots in inside your droneWill MacBook work instead?
