Calibration
Hi All,
Last question, do you need to calibrate for GPS everytime you use Phantom, or will it automatically set each time, if you don’t go miles away from area?
Craig[emoji106]
Check your sensor readings if you think there is an issue. Stay well away from anything metal at launch point. If you get a message that says there is a problem, verify what you are seeing. Traveling is not quite as much of an issue as some think even though there may be something in writing to lead you to believe that launching from your grandma’s house is a no no. Also, you’re not calibrating the gps. You’re probably thinking compass.
Short answer. NO
Reactions: Craig46
rockymountaincaptures
