Battery for FC 40
Currently flying with a bonka 2200 mah 11.1 v lipo...which barely fits in.anyone who can recommend a higher mah battery which can fit in a fc 40..name and brand and mah required.also are here methods wherein a larger battery can be strapped under the drone using some modification.last whats the max mah rating battery which may be used in this quad at 11.1v...can anyone also provide the internal dimensions of the battery compartment in centimeters etc..thanks
Maybe someone that still has one can chime in but is what I started with. As far as the battery compartment dimensions not sure why you can't measure that .Also don't know if you still can get parts for that model on e bay or not but did mine to carry extra batteries and sorry but this is the only
thing i have left from that bird. You can see how I used 3 batteries.
ADDED? Here are the battery plates I had
Done this...the easiest
Reactions: dirkclod
Whats the biggest mah capacity bty fittable in this configuration...in my fc 40
Hi..my dji fc 40 wont lift off even in full bty..i used it after almost 6 months or so of bty being in storage mode..which was fully charged before use.what could b the reason
ctlfreak
