There Are Now 4 P3 Areas, P3A/P, P3S, 4K & SE
Be sure to post in the correct location.
Thanks.
Thanks.
What is the main difference in the Phantom 3 and 3 4k?There are now 2 P3 areas. One for P3 Advanced & Professional and one for P3 Standard and the P3-4K
Thanks.
What is the best pilot app to use?There are now 2 P3 areas. One for P3 Advanced & Professional and one for P3 Standard and the P3-4K
Thanks.
Stick with the DJI Go App as that is the original. After you are confident in flying and know your machine well, if and when you find the need for more options then check out some of the other options.What is the best pilot app to use?
Thanks TJ, What are some options just wanna check them out?Stick with the DJI Go App as that is the original. After you are confident in flying and know your machine well, if and when you find the need for more options then check out some of the other options.
Yeah I saw that kit as well, thank you for the info TJ.I use iOS on Apple but I assume it is basically the same for Android devices. Do a search in the store for DJI and see what comes up. Litchi, AutoPilot, Altizure. Pix4D, DronePan, Vertical all come to mind but there are others I am sure. They build off a software developers kit made available by DJI.
Thanks.
Hi, I'm a new member to this forum. Which area would include the Phantom 3 SE? P3A/P or P3S/4K?There are now 2 P3 areas. One for P3 Advanced & Professional and one for P3 Standard and the P3-4K
Thanks.
P3S/4KHi, I'm a new member to this forum. Which area would include the Phantom 3 SE? P3A/P or P3S/4K?
@LuvMyTJ I am sure the title of this thread answers my question, but not wanting to mess up with drone 2. On the DJI go app under connect your device when selecting phantom 3 for my 4k since there is no category for p4k do I select p3s?There are now 2 P3 areas. One for P3 Advanced & Professional and one for P3 Standard and the P3-4K
Thanks.
You should have the option to choose your exact model. @dirkclod has a 4K, I flagged him so he can answer you correctly.@LuvMyTJ I am sure the title of this thread answers my question, but not wanting to mess up with drone 2. On the DJI go app under connect your device when selecting phantom 3 for my 4k since there is no category for p4k do I select p3s?
The forum has been updated to reflect the new model - Phantom SEHi, I'm a new member to this forum. Which area would include the Phantom 3 SE? P3A/P or P3S/4K?
