Aircraft resets and loses RC connection
Right now my P3SE is doing something odd where it seems to repeatedly reset, which ends the connection between the RC and aircraft.
Here's a description: I'll turn on the RC and aircraft, they'll connect (indicated by the back LEDs flashing green, the RC LED will be green), they'll stay connected for several seconds, then the drone will "reset" (the front red LEDs will turn off briefly, then turn back on), and the RC/aircraft connection will be lost (indicated by the back LEDs quickly flashing yellow, the RC LED will be red). After a couple seconds of this they'll reconnect, stay connected for several seconds, and the cycle will start over.
I've re-linked the aircraft to the RC several times and calibrated the RC, but neither of these seem to do anything.
I'm open to any thoughts or suggestions. Thanks!
Welcome to the Forum!
P3SE hooks to the tablet via WiFi?
Drone resets? It does the startup gimbal roll?
Link light status on the Phantom?
Anything we should know related when this problem started?
Rod
It sounds like a drone reboot. Many intermittent reboots of electronic stuff is caused by intermittent internal cable connections. Check all the cables you can get at to make sure they are fully seated.
Jesmith1016
