Ohh, I thought that the camera was basically self contained, and that the wires were for power and for GPS data only.
Are you talking about the regular Vision or Vision+, or both?
root@Phantom:~# opkg update
Downloading http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Collected errors:
* opkg_download: Failed to download http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/Packages.gz, wget returned 1.
src/gz chaos_calmer http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/Packages.gz )
src/gz chaos_calmer_base http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/base
src/gz chaos_calmer_luci http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/luci
src/gz chaos_calmer_management http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/management
src/gz chaos_calmer_packages http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/packages
src/gz chaos_calmer_routing http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/routing
src/gz chaos_calmer_telephony http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages/telephony
option http_proxy http://192.168.1.xxx:8888/
C:\dji\apk\DJI VISION_com.dji.vision_1.0.52_52.apk\lib\armeabi>
libamapv302.so
libamapv302ex.so
libapp_BaiduMapApplib_v2_1_1.so
libcom_google_ase_Exec.so
libDJICam.so
libdjivideo.so
libFlyForbid.so
libGroudStation.so
liblocSDK3.so
libvi_voslib.so
- another web server on port 1026 - This one you use to access pictures from phone app.
* When you go to "Album" apge in the app, it sends a control signal to the camera and camera enters "usb storage" mode, becoming visible as a usb flashdrive to this ystem that is then mounted to /mnt/sda1
Anyway, if you need to download the files, including dmg - you just need to enter the "Album" mode from your phone app, and after that use ssh from your computer to get content of /mnt/sda1. Use any number of freely available windows ssh clients, or openssh is already shipped with MacOS out of the box.
Smartphone antenna is not as good, as build-in directional antenna inside a Wifi Access Point is.
I tested a 2-3 km distance now, Wi-Fi video is excellent, with home-brew extender.
I tested the Ubuquity access point, the TP-Link 5210 access point, and Mikrotik wifi router.
All this 2.4 wifi devices worked great with DJI Phantom2 Vision+.
All you need to clone a wifi extender - is to configure 2 wifi interfaces in a bridge.
Interface#1 is configured as a client for hidden phantom SID (scan QR code to know it, or write it down from the DJI App)
Interface#2 is configured as an access point with any name (I prefer just "Phantom_extender")
Put this two interfaces in a bridge, switch phantom on, connect your smartphone to a "Phantom_extender" net, and have a fun with long-distance video going via powerful wifi access point.
Don't forget to switch off a factory "wifi extender" it is not needed now.
