ZenMuse retrofit to Vision+?
Hello,
Does anyone know if I can retrofit an H3-3D gimbal and GoPro to a P2V+?
Is it pretty much the same unit as the P2?
I have a broken/salt drowned P2 and want to swap out my bits including the gimbal and FPV and iOSD Mini to another working quad body.
Cheers
datamath said:
Hello,
Cheers
Yes I've done that myself and works perfectly.
You will have to use Phantom 2 tool to enable gimbal tilt control with the lever.
https://www.dropbox.com/s/17l9l7jgnijngmj/phantom2-tool.rar?dl=0
If your FPV kit is 5.8Ghz than you will have to swap RC transmitter and receiver as well.
I'm using 5.8Ghz RC transmitter/receiver and 2.4Ghz FPV kit.
datamath said:
Thank you. Are there any clear advantages to using the Vision+ over the P2?
I have converted my P2V+ that way only because Vision + gimbal/camera smashed in to pieces after a crash.
If you have a working P2V+ than there is no point in installing zenmuse and gopro on it as you will not be able to connect your phone/tablet to it anyway.
All you can do is convert it to phantom 2 with standard FPV kit.
