ddublu said:What do we know other than an updated version to support the Hero 4?
rgb62 said:I've been flying my Hero4 in the H3-3D without issues.
ianwood said:Unless you have made modifications to both gimbal and camera, you are likely not getting the best results and are putting excessive strain on the gimbal. An H4-3D gimbal will fix both of those issues.
It had better be configurable to accommodate an ND filter without adding weights in odd places. Not holding my breath on that one.
The h4-3d is for the hero 4 black not the hero 3, h3-3d is the one you should got.Joeg1937 said:I just bought one and the stabilization seems to be much better than the H3-2D that's what I had before. The only difference is that it hangs quite close to the ground.i am not happy with the plug in ribbon it plugs into the USB on the GoPro I liked the pin plug from the back much better, this ribbon is cheesy and if you should have a minor crash, there goes the gimbal.....
I am using a GoPro 3+ Black
