Zenmuse h3 3d stopped working after crash
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by a2dczealous, Mar 7, 2016.
  1. a2dczealous
    Hi all this is my first post.
    I have just bought the Phantom 2 with zenmuse h3 3d. I had a crash from about 3 feet and it must have hit the gimbal, it now doesn't work. I get no led and it won't level like it has no power, I have checked the connections internally/externally and all is good. It is being recognised on the PT2 Software, there are no updates and I have no clue what to do - I have tried the hard reset but as I said there is no LED so i'm stumped.
    I would appreciate any help.
    It was a working second hand unit so have no warranty.
    Thanks!
  2. jason
    Commerce Twp,MI
    There are only two possible reasons for it not to work. The cable feeding power to the gimbal isn't fully seated or damaged or one of the two exposed gimbals ribbon cables has been damaged. Check that the gimbal moves left and right freely if it does not the vertical arm may be jammed against the mounting frame. There is a small allen setscrew on the arm you can loosen to free it as shown in the photo. IMG_0024.jpg
  3. a2dczealous
    Thanks Jason,
    It looks like one of the ribbons are damaged on the gimbal, is this fixable?
    GUTTED!!!
  4. jason
    Commerce Twp,MI
    Yes it is repairable but I suggest you send it in for repair rather then attempting to repair yourself. This is the part you will need if you feel like doing it. Don't worry about the P2V+ as the Chinese don't know the difference.
    Flexible Gimbal Flat Ribbon Cable Flex Cable Part For DJI Phantom 2 H3-3D P2V+
Similar Threads - Zenmuse stopped working Forum Date
DJI Zenmuse H3-2D Gimbal stopped in flight Zenmuse H3-2D GoPro Gimbal Oct 18, 2013
Help!!! Problem with ph2 and Zenmuse H3 3D Zenmuse H3-3D/H4-3D GoPro Gimbal Jan 4, 2018
DJI Osmo Pro Kit (Zenmuse X5 Camera + DJI Focus Handwheel) Classifieds Oct 26, 2017
For sale: DJI Zenmuse X5 Gimbal and 4k camera with lens. Classifieds Oct 13, 2017
Zenmuse X7 Phantom 4 Pro Discussion Oct 11, 2017
