Zenmuse H3-2D accident lead to cut the black flat flix cable
I had an accident with my phantom and my gimbal was hit hard. My servo driver module (roll) stuck and it hardly moves. I try to fix it by disassembling the gimbal from the roll side. I found that there is a rotator attached to the electrical board that was moving hardly. I thing I fixed the movement issue but I ran into a bigger problem. the think flat black wire glued in the roll axis was cut. I want to know how to replace it. I am trying to know its specification but so far no luck. I need help to find a supplier or its specifications so I can find a replacement and fix it.
Re: Zenmuse H3-2D accident lead to cut the black flat flix c
You will probably have better luck doing a Google search with the Name and model # of your servo. and it helps to know
if it has metal gears "MG".
I'm not sure if parts are readily available, or if you have to replace the servo.
I got the same problem!
In my case the tilt servo is damaged.
Anyone know how to disassemble it?
I really like to have a technical datasheet of the H3-2D gimbal!!
If the servo motor is stuck, it helps to turn the shell of the servo counterclockwise with your fingers while blocking the movement of the gimbal.
cokersean20
