Zenmuse and Kumbacam DJI Phantom 2 FPV Kit
"If you are using a Zenmuse Gimbal, you will need to buy a plug-n-play adapter (easiest method) or buy a balance charger (Use included batteries). " - this is in the description for Kumbacam DJI Phantom 2 FPV Kit.
It says there is no balance charger... can the Li-Po charger that was included in the Phantom 1 the BC20-4 be used to charge the battery for the FPV's battery?
I have the answer to this which is "yes.. only use 1-2 amps - attach battery to 2s." Thanks!
wkflysaphan4
