Zemuse H3 3D
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by maxta97, May 5, 2014.
  1. maxta97
    not sure if anyone has had this problem or can advise me but when i connect the my Gopro 3+ black addition to my H3 3D gimbal and power it up everything seems fine viewing it through my Black Pear Monitor running an immersion 600 mw transmitter through to the spiro net antennas to the monitor but here is the problem... the gopro will bleep then shut down the switch back on and intermittently do this which will cause the recording to crash and have to be file repaired. Then on occasion it will completely freeze and i will have to remove the camera from the gimbal and remove the battery. Sometimes after continuos rebooting and fingers crossed it will work and record of 1000 meters out stop working and i have to use the OSD on the blank screen to get me back. can anyone help me with this ?? Thanks i would like to add the only thing i did different with the installation was avoided the solidering of the connecting wires and purchased a ready made wiring
    here is the link to the cable i bought is it ok to use ??
    http://www.ebay.co.uk/itm/Plug-and-Play ... 258d9c53be
  2. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    try updating GoPro software.
  3. OI Photography
    Clarksville, TN
    Thread moved to H3-3D section
  4. maxta97
    hi yeah i did that by copying the update to the sd card and performing the update but it still did the same but i cant figure it out as sometimes its fine but more often not and it seems to be getting worse
  5. maxta97
Similar Threads - Zemuse Forum Date
P2 NIB W/h3-3d zemuse NIB Classifieds Jan 10, 2016
Zemuse h3-2d or 4d and phantom 2 vision Phantom 2 Vision Discussion Dec 4, 2015
Zemuse h3. can use it with lipo only? Phantom 2 Help Apr 6, 2015
zemuse 3h-2d and go pro3+ (go pro battery discussion) Phantom 2 Discussion Jan 1, 2015
few issues with the zemuse h33d Zenmuse H3-3D/H4-3D GoPro Gimbal Oct 25, 2014
