YouTube live stream - 1 frame / sec ?
Mesa, AZ
Running Nexus 7 2013/gen2 and latest app/firmware. I tried YT live streaming last night and while it did work, I got a 1fps stream! There was about a 30 sec lag, no problem there, but the frame rate was unusable slow. I started from scratch 3 times and got the same result. I checked receiving the stream on an iPad and a lightning fast PC/Chrome.
The WiFi in our house (including internet speeds, fiber 20 Mbit/sec UP) kicks a**. I tested with speedtest.net to remove net speed as a possible issue.
Is there something I can do? Maybe use the iPad GO app?
There are many having issues with the Nexus alone. Streaming is just pushing it harder. Were you getting a good FPV image yourself on the tablet? And did you run speedtest on the tablet, or something else?
Not a powerful enough tablet. Only android tablet powerful enough is the nvidia shield really. Even then the built in streaming sucks. Stream to Shou or if you get a shield stream to twitch and that is buttery smooth.
What are Shou and twitch? I will try with the iPad Air 2. I tested net speed on the Nexus, 50 Mbit down, 20 Mbit up., 6ms ping. The FPV video was fine, even with streaming enabled.
Reactions: III% Streve
Did you ever get around to testing streaming with an iPad Air 2? I'm considering upgrading from my mini 3 and am looking for options.
cokersean20
