Yet another prop guard
Yokohama, Japan/Taichung, Taiwan
360 degree bumper made of steel/CFRP. Lightweight, around 100g.
I bought it from local R/C store in Japan. I think it's the shop's original.
I tested today.
Of course, it affects front view - in 16:9 footage, it'll be in unless 10-20+ degree down camera. The followings are taken in 5 knot head wind (equiv. 10m/sec forward moving).
The 12 steel wires are easy to attach/detach. Once attached 4 arms using screw driver (each 2 motor fixing screws), can be fold without screw driver - however it extents about 1cm, and it's hard to put into my bag (Vanguard up-rise 48). Without wires, the arms itself will be instant guard, I think.
Today I didn't crash :) so I don't know about its strength, but seems very tight.
Monte55, Fplvert: if you're worrying steel about magnetic, this product is made by non-magenetic materials (I confirmed)... even magnetic, too thin magnetic density and too far from IMU. :) The straight wire curves with tension, so it cannot be alternative by plastic. Also lesser strength when hit.
