Yaw stick gains?
Discussion in 'Phantom 2 Discussion' started by FASTFJR, May 9, 2014.
  1. FASTFJR
    South East PA
    Where is the gain setting for Yaw?, is their one? I would like to slow it down to about half if that is possible
  2. adanac
    NYC
    If I'm not mistaken yaw is controlled by the rudder (R) adjustment in the setup assistant. I found that in order to control the yaw the way I wanted to - in order to achieve slow, film-like pans - I had to do so in my controller (Futaba T8J).
  3. FASTFJR
    South East PA
    Thanks, yea thats what I kind of thought. Didn't know if you could do it with the factory box
  4. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    In basic - RC - settings for all gains including yaw, but an aftermarket Tx you can fine tune the yaw settings
Similar Threads - Yaw stick gains Forum Date
P4 stick input - yaw video transmission Phantom 4 Pro Help Apr 24, 2017
Better Yaw shots - Transmitter sticks adjuster Phantom 2 Vision + Discussion Mar 10, 2015
Yaw has flipped to the right stick Phantom 2 Vision + Discussion Feb 10, 2015
Can the Yaw (left stick) sensitivity be adjusted? Phantom 2 Vision + Discussion Jan 25, 2015
Phantom 2 + Zenmuse Pan issue + stick yaw Phantom 2 Discussion Nov 14, 2014
