Yaw smoothness
OK......First lets try this....on the stick theirs a top part that's adjustable by loosening the nut and turning the top part counter clock wise to make the stick longer...just don't for get to run the nut back up to the top part and lock it finger tight. In the picture 1 is the knurled nut and 2 is the part that you turn counter clock wise to make stick longer as a longer stick will make for much improved s m o o t h e r stick movements ! Good luck ! !
Change the exponential settings for the rudder(yaw) to dampen the yaw.
And Yes even the smoothness of the gimbals camera movements.....slow OR faster.. Good Morning Stuka *
All good advice, +1 and the Yaw Expo settings.
Reactions: MotorCycle-Man
there is also a setting I wasnt aware of before. Yaw endpoint setting in the exponential screen, More affect than expo. Change the setting to around 50. Try different Numbers for your preference.
cgarner1
