Yaw settings and horizon drifting tilt?
Syracuse, NY
I've noticed that when filming, if I yaw then the horizon seems to tilt but will slowly recover once I stop. I have a level horizon otherwise its just a problem when yawing. If I go really slowly it is less noticeable but that isn't that easy. Are there setting to help eliminate this tilt?
There is no setting to fix this. It has been a widely discussed issue so you should find plenty to read about if you search the forum.
I know this is not what you want to hear, but those who suffer from a drifting horizon are rarely able to find a way to correct it short of sending the P3 back. No amount of calibrations will fix it, but sometimes a new FW update accidentally fixes it for a lucky few.
cokersean20
