I've copied this across from a post I did in another thread on here. No response there, so will try here instead.
I recently upgraded my assistant software and RC controller software to the latest versions.<br /><br />The Phantom flies fine , BUT the H33D gimbal tilt doesn't work anymore.<br /><br />I have tried the X1 calibration in the Assistant software but the slider won't move and is coloured red. If I hit reverse or norm, the gimbal does move so the receiver port is working and transmitting. I have also opened up the Tx and used a screwdriver in the potentiometer so I know it is not the switch that's not connecting with the potentiometer either.<br /><br />My feeling is that it might be a software problem to do with the upgrade on the DJ6 controller I'm using. After the upgrade the light on it turned from red to green and it now beeps when I turn it on. I'm aware of the other thread about this issue but crucially that Phantom doesn't seem to work - mine does fly perfectly and only the gimbal tilt is affected.<br /><br />Any help would be gratefully received.<br/>
