X1 Calibration Issue
Discussion in 'Phantom 2 Discussion' started by PhantomNoob, Apr 15, 2014.
  1. PhantomNoob
    New Braunfels, Texas
    I reinstalled my operating system, and in turn needed to redownload the DJI Phantom 1 assistant software, RC assistant, and driver. I was running version 1.08, but the only option I had was the 2.0 upgrade. I installed it, upgraded, and then lost the ability to calibrate X1. It either doesn't move, or when it does, won't traverse entirely. I started searching the forums, and found someone had placed a link to revert back to 1.08. So I followed through with that in hopes of fixing the gimble tilt issue. So far, no luck. I've tried the RC assistant as someone suggested, I've upgraded, the reverted, and all other options I can find here. Any suggestions?
  2. DxJxI
  3. RickD
  4. PhantomNoob
    Thanks DxJxI, but I found a link here to revert. That hasn't fixed the problem. Someone suggested all you needed to was upgrade/revert, then use the RC assistant to calibrate the sticks, then open the Phantom 2 assistant and calibrate X1. What's happening, the tilt won't calibrate. It will go to 1000, but won't go back to -1000, but only to the midpoint. It's like the potentiometer is broke.
  5. NYRangers99
    Westchester County NY
    there are threads on here that explain exactly how to do it…I had the same problem..you MUST follow the directions exactly as they are written or it will not work…If you do one step before the other it won't work…Trust me I was so frustrated and someone explained exactly what to do in the specific order and it worked
  6. NYRangers99
    This is exactly what you MUST do step by step…thanks to Raptor it finally worked!
  7. ginsonic
    Have you update the RC firmare too?
    P.S. For 2.0 Phantom Assistant need 1.1 RC assistant
  8. PhantomNoob
    I've reverted to Phantom Assistant 1.08, we may have determined the issue, it appears I'm running RC Assistant 1.1. Does that force me to run 2.0, or does anyone have the older version of RC assistant available, as I've run those steps in that exact order without success?
  9. mrand
    I'm having this issue and I'm not sure what you mean by "upgrade" or "downgrade". I will try everything again, but I'm not holding out much luck. Everything worked fine with the 2d gimble and now the 3d is causing me this headache where the x1 is either level or straight down.
  10. mrand
    I'm on a mac and on the DJI website I can download v2.0 or v3.0. Common sense would tell me to download v3.0 as it's newer. I would assume it would have everyone 2.0 has. Why does this stuff have to be so confusing? I don't see why they can package all the software to 1 program.
  11. Raptor
    "upgrade" or "downgrade" means the same thing: reinstall the firmware of your P2 using a different version of the Phantom Assistant.
    Example 1: connect your P2 with Phantom Assistant Version 1.08 and you can choose to "upgrade/downgrade" your P2 to Version 1.08
    Example 2: connect your P2 with Phantom Assistant Version 2.0 and you can choose to "upgrade/downgrade" your P2 to Version 2.0
  12. mrand
    OK, thank you for clarifying.
  13. yummer30
    Hi.. do I need to calibrate the control sticks or only the X1? In RC assistant?
Similar Threads - Calibration Issue Forum Date
Phantom 4 Pro - Compass Calibration issue Phantom 4 Pro Discussion Sep 27, 2017
Sensor Calibration Issues General Discussion Apr 2, 2017
P4 Sensor Calibration Issues Phantom 4 Help Jan 15, 2017
Standard IMU Calibration Issue/ Legs shaking Phantom 3 Help Jan 14, 2017
Calibration Issues Standard Jan 2, 2017
