- Joined
- Oct 26, 2015
- Messages
- 23
- Reaction score
- 0
- Age
- 54
Hi guys,
I have just setup an S900 as follows:
Wookong M
iOSD Mark II
Corona 14 Channel (Futuba) Rx
Alexmos GImbal / Camera
LB1 and 2 ground stations
Everything seems okay and the plan is to control the gimbal directly from the Rx without any Wooking interactions. Basically, there is wiring from each of the Rx ports to the appropriate Wookong ports. S Bus is not being used.
On the LB air unit I have a DJI gimbal port plug that supplies the power and a connection the the Wooking canbus system. The only other connection to the air system is the hdmi feed from the camera. The theory being the OSD data is sent from the iOSD to the LB via the canbus then onto my screen be it a HDMI connection or into an iPad etc.
I have two issues I can't resolve and hoping a guru in here could advise.
1, There is no OSD data showing, only the basic overlay. The map however is updating and,
2, Whilst in GPS mode the Wookong LED flashes a constant blue led.
If anyone can advise what I could be doing wrong it would be much appreciated.
Wookong M
iOSD Mark II
