Won't take off
Discussion in 'Pro/Adv Discussion' started by Kevin Greenspan, Jul 17, 2016.
  1. Kevin Greenspan
    Always carefully boxed up in a back pack case. One side seems to want to raise up, the other won't. Seems like not generating enough rpm to have any power. All props spin up. Tried replacing a couple of motors on the "weak" side. No change
  2. Traveler
    Sounds like you changed your stick mode, take a look at that first in the go app.
    I also recall a like issue being correct on the advice from msinger that was fixed with a "remote controller calibration", also on the go app.
    #2 Traveler, Jul 17, 2016
  3. Kevin Greenspan
  4. Kevin Greenspan
    Same problem with iPad and iPhone apps. Didn't change the stick configuration, recalibrated everything and upgraded all bird and RC S/W
  5. Traveler
    I wouldn't think there's not much more to consider from a software perspective. ESC reacts to commands from the sticks on the RC, so I suppose you could try a simple test with Litchi. A simple mission in an open area, just a launch and land using the waypoint feature, keeping it very low of course. This could help tell if the problem is from the RC or the ESC. What changed from the last time you flew it? Crash, long storage, or something your not thinking of.
    #5 Traveler, Jul 17, 2016
  6. Kevin Greenspan
    Does the same thing in Lichi. No weird storage bumps or crashes.
  7. Traveler
    Ok, so I know we already talked about stick mode, but with everything turned on, can you double check that it is set to stick mode 2. Should look like this.
    [​IMG]
    I only keep bringing it up because it happen to me once and every time I tried to lift off it was really telling it the reverse.
    If this doesn't work than I would think you may have an issue with the ESC. On the P3P I guess it's on the main board, but from what in have read, some of the other earlier models use a separate/user changeable component.
  8. Traveler
    Another good test, again in a wide open area, auto takeoff and auto landing. If it can't even do this, than you must have some electronic failure with the aircraft or a corrupt firmware issue. Also I am assuming through all this you have already looked at your battery voltages.
  9. Kevin Greenspan
    Dropped it off at a repair place. I'll keep you posted. I tried all of that. Must be an ESC issue
  10. Traveler
    10-4
    Hope it doesn't cost too much to fix.
    Best of luck and yea, please keep me in the loop.
    Cheers
  11. Kevin Greenspan
    I'll let you know how it works out.
Similar Threads - Won't off Forum Date
Remote Control won't turn off General Discussion Wednesday at 11:38 AM
Won't take off Standard/4k Discussion Jul 10, 2017
Standard Won't take off/Motors not working Phantom 3 Help Jun 17, 2017
Standard P3s won't take off Phantom 3 Help May 15, 2017
Work around when Go App won't let you take off Control (Go, Litchi, etc..) Apr 12, 2017
