Won't connect to assistant
Discussion in 'Phantom 2 Vision + Discussion' started by Mori55, Jan 26, 2015.
  1. Mori55
    NJ-USA
    Last night I was doing a advanced imu calibration and it wouldn't "stick". So I thought I just shut down till this morning. When I plugged into assistant , nothing , it doesn't see my phantom.
    This isn't new and I've been doing this for years and never had this happen. The LEDs on the phantom are blinking that I Ned a imu calibration , but when I plug my phantom in , nothing , even changed usb cables.
  2. justin00
    Australia
    Can you try another PC and or reinstall USB driver?
  3. Mori55
    NJ-USA
    I don't have another pc. I would have one if it wasn't for the phantom. I usually just use my iPads for everything. I tried to reload the dji driver and it wouldn't go.
  4. BlackTracer
    Winter Park, FL USA
    I know you are experienced, but try this:
    -- In your PC Control Panel->Programs and Features
    -- Find the DJI Driver installation and uninstall (listed as "DJI driver version 2.02")
    -- Connect your Phantom to the PC and turn on the Phantom
    -- Find the DJI Driver installer on your PC that you downloaded
    -- Run the installer
    This should do a fresh install of the driver. Hopefully this resolves your issue.
  5. diane
    I am having the same problem. Could it be the USB cable? I have about 4 of the same one and am unsure which one came with the Phantom. Tried reinstalling the software and it still doesn't recognize the Phantom.
  6. mede8er
    There is nothing special about the Phantom's USB cable....if the cable works on other devices it will work....
    Most likely PC/Mac related as BT said....
  7. BlackTracer
    Winter Park, FL USA
    Can you give details of what software you reinstalled? And are you on PC or Mac? USB cables can fail, but if you have 4 of them, one of them is bound to work. Did you uninstall and reinstall the driver, if using a PC?
Similar Threads - Won't connect assistant Forum Date
[Solved]Phantom 2 assistant won't connect after motor replacement Phantom 2 Help May 3, 2017
DJI Assistant 2 Won't Connect Phantom 4 Help Jan 2, 2017
P2 won't connect to Assistant Software v3.8 Phantom 2 Help May 27, 2015
Assistant won't connect to PC Phantom 1 Help Sep 28, 2013
RC won't connect to Phantom 4 Phantom 4 Help Jan 7, 2018
