With or without GoPro battery?
Discussion in 'Zenmuse H3-2D GoPro Gimbal' started by Darrell1, Jul 13, 2013.
  1. Darrell1
    My gimbal arrives Tuesday. Does anyone know if I can install my GoPro to it without the battery in the GoPro? I'd like to save that weight.
  2. edunwody
    South East, USA
    Mine has not come n yet but I understand the GP needs the battery to operate even while plugged in. My fpv also powers my GP but want work w/o battery.
    Edit: A good way to check is to see if the GP powers up w/o battery while you are in charge mode.
  3. defreerider
    Antigua
    In my limited experience I have found out gimbals like to have the battery in the gopro as it seems the gimbal is calibrated to allow for the complete weight of the camera. For me it's a shame that the Zenmuse gimbal can't use some of the gopro power as it (the gimbal) has significantly reduced my flight times.
  4. jumanoc
    Only GoPro3 Black Edition doesn't works without it's battery. With the other models you can uses them without own battery.
    Related to weight, that is a "wanna be ligther phantom", because if you take out GoPro battery for reducing weight, may be you'll get some grams lighter, and may be some longer flight time, but your main battery will power your GoPro, so that will reduce the flight time... because more juice required.... so no winner here.
Similar Threads - without GoPro battery Forum Date
GoPro H3+ will run without battery Photos and Video Aug 21, 2014
Flying without GoPro battery?? Zenmuse H3-2D GoPro Gimbal May 13, 2014
Using Gimbal for GoPro without soldering :) Phantom FC40 Discussion Apr 28, 2015
Flying without the GoPro Zenmuse H3-3D/H4-3D GoPro Gimbal Jan 27, 2015
behavior of gimbal without gopro attached Zenmuse H3-3D/H4-3D GoPro Gimbal Dec 15, 2014
