wiring harness to camera help
Had a bit of a crash.....the wires pulled out of the molex connector that attaches to the camera (see pics) it was clean and it seems that I can just re seat the wires in the connector, but there are 6 wires and 8 ports on the harness. Could someone tell me the proper placement for these six wires in the molex?
Here is a picture of that cable for ya
This cable comes as part of the Phantom 2 Vision plus cable set. you must make sure that the big cable with all three connectors is included in the set to get that cable. I think you will beable to get those back in if you take your time. I have done it. Usually the little connector is the one that breaks as that one and the other one on the front just pull out.
Thanks for the help....unfortunately, despite the help, it turns out I fried something else. I am going to replace the board that comes with the wiring kit and change the harness what pulled out. I believe it may have shorted when the wires pulled out on impact.
What is going on with it. perhaps someone, even me, has dealt with it. Just a question, and I am sure you did look under the hood and reseat the other end of those cables. good luck
shimuafeni fredrik
