Will this work?
Discussion in 'Phantom 2 Discussion' started by maxopie, Mar 16, 2014.
  1. maxopie
    I am fairly new to FPV and the Phantom 2, but I have been researching and I was wondering if the current setup listed below will work, and/or the most effective. Thanks!
    - Phantom 2 (regular)
    - Zenmuse H3-2D Gimbal (For stabilization and so I can rotate)
    - iOSD mini (Give inflight data)
    - 2.4G Bluetooth Datalink (So I can navigate using iPad)
    - Something so I can see what the GoPro sees
  2. Tmesis
    You're there. Call up your model shop and buy it.
  3. maxopie
    So, just to be clear, I will be able to use the video transmitter, the iOSD mini, and the 2.4G , with no compatibility issues?
  4. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Two rather important things to note:
    • Ground station does not give you FPV capability. You cannot see what the camera sees.
    • Ground station is not enabled for the P2 yet. It will be soon but we're still waiting for DJI to supply the firmware that makes it work.
  5. maxopie
    Thats what the Video transmitter would do, but I wanted to make sure you could have both hooked up at the same time
  6. ianwood
    Staff Member
    Lost Angeles
    Yes, both will work at the same time. You'll have a fun time keeping all the antennas away from each other but yes.
  7. tupes
    New Orleans, La
    I've been told not to use any bluetooth with that or on the gopro wifi because the controller is 2.4ghz and it may cause problems in flight. If I'm wrong someone please correct me. I might have my info mixed up.
