Will these antennas work?
Discussion in 'FPV (First Person View)' started by billnast, Dec 24, 2014.
  1. billnast
    Hey everyone just ordered a 7ch black pearl. I already have a set of fat shark spyronet cloverleaf antennas that have female connectors only. Will these work with the 7 channel or will I need an adapter or possibly new antennas? Link to exact antenna is listed below.
    thanks guys!
    http://www.amazon.com/gp/aw/d/B00KAOT4LM
  2. jgarraffo
    I'd be curious to know your results. I'm using one clover leaf right now from DSLR Pro's and I'm really very happy with it. Not sure if there is compatibility issues. Again, curious how this works out, if you do go through with it.
  3. Diesel31
    Long Beach, CA
    The Spironet antennas work pretty well. You'll have to check the type of antennas to make sure they work. I have the 7 channel BP to use with the Fatshark channels and the antenna is RP-SMA. I thought it was supposed to be SMA, but I had some RP-SMA antennas so they worked fine. Just make sure you know if you get the SMA or the RP-SMA. Fatshark makes both versions or you could get an adaptor. I prefer to avoid the adaptor. Not sure if it's just an irrational thought of mine, but it seems the adaptors don't provide as smooth of a signal...or that has been my experience. Another thing about antennas, make sure you have them on pretty tight. That seems to provide a smoother signal... Again, just my eyeball experience.
    Here's my 2 cents. I've used the Fatshark Spironets and they work pretty well. However, a better set-up (works well with interference and gets good penetration ie. Semi-dense trees) would be the VAS 3 turn Helical and a VAS Mad Mushroom on your monitor and a VAS Airscrew on your VTX. I use just a 3 turn Helical on my goggles (no diversity) and it has a wide enough beam as long as I'm pointing in the general direction.
    Anyway, good luck and happy FPV'ing!
  4. billnast
    Thanks guys.
    Diesel - I have ordered a cheap adapter in the hopes it saves me a headache. Link below hope it's what I need lol. Ya I was looking at helical just now and I am very interested. Looks like better technology. I will most likely order new antennas after the BP arrives. Will let u know when it comes in.
  5. billnast
Similar Threads - antennas Forum Date
Standard How to orient aftermarket antennas? Phantom 3 Help Friday at 3:02 PM
New Antennas Standard/4k Discussion Aug 1, 2017
P3P Original remote antennas Classifieds Jun 22, 2017
MaxxUAV.com Finally getting Dual Band Antennas! Phantom 4 Pro Discussion Jun 21, 2017
Standard Phantom 3 Need Help with Antennas Phantom 3 Help Jun 14, 2017
