Will iPad Air fit in the P4 case?
As the title says will an iPad Air fit into the P4 case. I seen a video and it looks like the iPad mini fits but does anyone know if the full size iPad will fit?
Thank you.
iPad Air 2 will fit in the microraptor case with the props on if you use a thin case. If you use an otterbox it will fit in the case but will contact the props.. So I usually keep the iPad Air 2 in a cheap thin case and keep the props on.. If I'm traveling I take the props off put the iPad Air 2 in the otterbox. It then can be kept in the microraptor case.
Thank you.
no the ipad air will not fit into the case the phantom 4 comes in
That's right, will not fit. I wrongly tried to modify the case so it will fit, and to no avail. Will fit horizontally, but the height will be too much for the poor case size!
cokersean20
