Wifi range down after update
Hi I have after updates firmware and camera update, app update my wifi range is down was getting over 4600 feet with still good signal then after updates in down to 2000 feet and signal is hit and miss have downgraded to 1.08 but it's still the same so must the camera update doing it anyone any ideas how to downgrade the camera firmware
Thanks for your reply Geert not worried about the waypoints but it does look like they have put a restriction on the range you can get now :?
Geert was checking flytrex is that you on it of a range of 1.1 miles you don't seem to be having any problems with wifi dropping off like me are you using your new horizon Antenna ?
I found a link to download 1.1.8, if anyone want to try a downgrade, maybe the txpower or something is changed in 1.1.8 because i know in 1.1.9 when you connect to camera via SSH it say -5 dBm as you open the connection...
http://download.dji-innovations.com/dow ... rmware.zip
If anyone try to downgrade, please post your results here to help others.
Thank you.
