- Joined
- May 27, 2014
- Messages
- 16
- Reaction score
- 2
Just went to try update my P3 and it is not even showing a wifi signal coming out of it. No way to connect to it or format my SD card which my computer says needs formatting. Any suggestions?
The P3 doesn't use WIFI.....It connects directly to the controller via the USB on the TX......Maybe you worded your question wrong or I didn't understand it?Just went to try update my P3 and it is not even showing a wifi signal coming out of it. No way to connect to it or format my SD card which my computer says needs formatting. Any suggestions?
Glad you got it figured out. Yeah, the P2 and P3 are different animals all together under the hood. If you were able to do the firmware updates without a hitch you're already ahead of the curve!I'm so used to the P2, this **** gets confusing. Especially with the better advice usually coming from the forum. the bottom line is I have no connection, plugged into USB. Online help suggested deleting the app and re downloading it. that worked.
