Hi, I just bought wide landing gear for my phantom. I'm scared to put it on because I don't want to mess up the GPS signal and the other thing ( not sure what the other thing is ) please help. Is there a video that I could watch or some tips and how to remove the GPS and the other thing to put on my wide landing gear?
I think you mean the compass... the GPS module is under the center of the top shell. The compass is on the landing gear. I would think that if you were going to replace landing gear, keep the compass in the same approximate position and on the same side, and try not to use a magnetic screwdriver because if it gets too close it could do wacky things to the compass.
If you have the newer P2 v2 version with the molded compass to the rear leg of the landing gear you may have a problem with placement on wider landing gear.
I went about it in a different way which was more expensive by changing the cameras stock lens to a 5.4 mm f/2.5 60° 10 mp lens no fisheye, no landing gear or props in the video to crop out and the results for me were great.
I suggest that you order the lens and the lens mount that way all you have to is exchange as complete assembly. Total price including shipping is $157.22. To focus the lens you would need a micro mini to standard HDMI cable which you can get at Best Buy.
