Advanced Why does it need cellular & GPS?
Discussion in 'Phantom 3 Help' started by Sammynels, Jul 21, 2015.
  1. Sammynels
    MA
    I've been reading all the threads about tablets and I'm confused as to why it needs cellular and a GPS antenna if everyone says you should cache maps via WiFi before leaving home for the area you will be flying in and then use Airplane Mode? Thanks!
  2. Roboionator
  3. Meta4
    Meta4 Moderator
    Staff Member
    You don't NEED cellular or GPS in your tablet.
    You can fly just fine without and if you want maps, it's easy to cache them at home and they'll be available when you fly.
    You need GPS in your tablet only to be able to reset your Phantom's home point to the tablet location.
    And if you have an Ipad, the only way to get GPS is to buy the cellular version.
  4. Sammynels
    MA
    Ok, but can't you manually pick your RTH point on the map you cached (assuming you know where you are on the map) without using GPS to show you where you are?
  5. Sammynels
    MA
    Are there any tablets that have GPS without cellular that you recommend?
    I know with the iPad, to get GPS you have to get cellular because the WiFi only version doesn't have the GPS antenna.
  6. Meta4
    Meta4 Moderator
    Staff Member
    Not that I'm aware of.
    But this is no problem for most flying.
    RTH to takeoff point is perfect for most uses.
    Many (most?) Android devices have GPS.
  7. Sammynels
    MA
    Thank you SOOO much!!! I'm not going to be leaving my take off point by driving or boating around while flying. As long as it knows where it took off so it can RTH to that point, I don't need GPS or cellular!!
    Since everyone seems to prefer Apple products because they work better with the DJI app, I can pick up an iPad mini 2 for $129 on EBay.
    Thanks again!! Happy flying!!
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    There are only two choices when resetting the home point -- both require GPS. You can reset the home point to the current position of the Phantom (which uses the Phantom's GPS). Or, you can reset the home point to your current location (which uses the GPS from your device). The second option will of course only work if you have GPS on your device.
    If you decide to go with an Apple device, you don't have to activate the cell service in order to use the GPS. You definitely must have a cellular model though.
    ems1016 likes this.
  9. ems1016
    Clinton, New York
    Since DHP doesn't (presently) automatically update periodically (as it was originally purported to do), you still have to remember to reset it periodically. Seems to me if its not automatic, there's no real advantage (presently) to using DHP over RTH, the latter of which also can be re- set periodically.
Similar Threads - does need cellular Forum Date
Aircraft locked. Update needed. Does not update! Phantom 4 Pro Discussion Saturday at 11:40 AM
Why doesn't DJI give you the cables you need? Phantom 4 Discussion Jul 20, 2017
How many batteries does one really need, and other deep thoughts? Pro/Adv Discussion Mar 19, 2017
Does anyone use powerdirector/photodirector? I need the Lens Correction Profile for the p4p Phantom 4 Pro Help Dec 10, 2016
Does p4 need rest between batteries Phantom 4 Discussion Nov 14, 2016
