why does firmware not appear to address 1 missing motor?
So 1 motor or ESC can fail in a flight. Why does the firmware (fw) not address this real possibility?
I would assume if monitored properly, the fw could see a dead motor, and based on the IMU data, modulate the other 3 to make up for it. Should not be so hard to do. It could even use motor current drop to show a prop broke or spun off....
Why on a $ 1300.00 sophisticated device like this is that not addressed?
If you lose one corner of a quad it falls from the sky. Three props is not enough to support flight.
If you had a hexacopter you could possibly compensate for a failed motor.
Why didn't Henry Ford put disc brakes on his Motel T?
Multicopters are quite recent inventions and are still evolving.
skyhighdiver said:
all they need to do is install it in the firmware :evil: :evil: :evil:
And have enough power in reserve to carry the weight of the quad.
Just because it has been demonstrated to be possible doesn't mean that a simple firmware update to make NAZA do it.
It could only hope to spiral down to the ground with 3 motors due to the fact that 1 motor cannot counteract the torque from the other 2.
With a hexacopter or octacopter it can be done, and many systems do have the capacity to recover, but it is almost impossible for a quad.
It should be easy enough to cut the opposite motor, throttle up the remaining two, and have some semblance of slower controlled descent.
And do all of this for a price that we can all afford?
skyhighdiver said:
http://youtu.be/bsHryqnvyYA
[youtube]https://www.youtube.com/watch?v=bsHryqnvyYA[/youtube]
There is more to it than just adding some code to the firmware.
The craft in the video is a much lighter and a better balanced quad than the Phantom with gear hanging off of it.
Maybe in the future we will see this feature implemented.
The quad configuration is under-actuated as it is.
That is to say the 4 controllable DOF (Degrees Of Freedom), available as the speeds of the four motors, is fewer than the 6 DOF the quad, or any rigid body in space, can achieve.
In Robotics it would be described as non-holonomic.
It is not a trivial task to try to control an under-actuated system (quad) as it is let alone with the loss of a control input. The nonlinear dynamics are difficult to model and it is unlikely the Phantom will ever see such an upgrade.
I am glad a lot of you are not scientists or engineers! If so, we probably would not yet have gas stoves, dishwashers, or manned flight.
Luckily there are enough of us who are obviously too dumb to know something is impossible, like you know.
Wilbur and Orville Wright faced a lot of similar comments about it is impossible too in their day.
Three props is not enough to support flight. -- Glad to know that, but in meantime, please watch the video above to see one fly this way...
Why didn't Henry Ford put disc brakes on his Motel T? -- I was not there so cannot answer this, but I can assume from your comment that you mean in the beginning of a new-ish product, no one should innovate new ways...
And have enough power in reserve to carry the weight of the quad -- Please see Three prop reply above to see how wrong you are...
Just because it has been demonstrated to be possible doesn't mean that a simple firmware update to make NAZA do it -- so if it is not easy, don't do it? Actually, if you follow the subroutine algorith Mark Mueller, a lowly student in school, developed, it is indeed an algorithm that can simply to added to any flight program - read his pdf - he has already begun offering it.
It could only hope to spiral down to the ground with 3 motors due to the fact that 1 motor cannot counteract the torque from the other 2 -- please tell that to these guys - they obviously are not controlling their quad with 3 rotors active:
http://robohub.org/quadrocopter-failsaf ... ller-loss/
And do all of this for a price that we can all afford? -- I think you are not an entrepreneur; of course for a price we can afford as it is already done and there is no cost adder for new hardware to the drone to implement it.
There is more to it than just adding some code to the firmware -- I can see how you would have reacted to poor Wilbur and Orville....
The craft in the video is a much lighter and a better balanced quad than the Phantom with gear hanging off of it -- Nonsense comment. The algorithm is just as applicable to a 500# quad as to a 10 oz one. Please see post above for a dji size if you still think all this is impossible.
The quad configuration is under-actuated as it is. That is to say the 4 controllable DOF (Degrees Of Freedom), available as the speeds of the four motors, is fewer than the 6 DOF the quad, or any rigid body in space, can achieve. In Robotics it would be described as non-holonomic. It is not a trivial task to try to control an under-actuated system (quad) as it is let alone with the loss of a control input. The nonlinear dynamics are difficult to model and it is unlikely the Phantom will ever see such an upgrade. -- Just wow. Again, glad there are some of us too dumb to understand your self imposed limits, and dumb enough to believe some things some folks think are impossible are not.
Or perhaps too dumb to realise that people have answered the question you asked, which was:
Maybe when you buy a Phantom 4 or 5 it will have this feature implemented but it's not going to happen for a Phantom 2 because it is very heavy and incapable of generating enough thrust to stay in the air with only 3 props running.
The feature you're so excited about is a very recent development that has only been demonstrated and has not been implemented in any production quad.
For it to work, the quad will have to be designed and built with an appropriate power to weight ratio.
It's not something that can just be bolted on as an update to an existing quad.
Of course you are welcome to come up with your own home redundancy proofing system if none of this makes sense to you.
Or perhaps too dumb -
meta4, I am sorry, but a drone that can raise itself at over 6m/sec is certainly strong enough to prevent failing out of the sky with 75% power.
I do not understand why you take this so personally, or why you feel a need to defend firmware from being improved. Unless YOU designed this unit, you do not have the knowledge to make such a limiting statement. Just admit you believe it is 'impossible.' Enough.
Companies that produce products can implement what they want and when they want. Most companies do not release every option to a particular product until they test it and plan it's release to gain them the most profit. The feature you describe will most likely make it to market sooner or later. If it is a proven technology companies will implement it. It just hasn't happened yet. The same way there are no mass produced flying cars and such. The ideas are out there, sometimes the technology is not.
So it seems the best thing to do here is to agree to agree I guess since we all agree it will be a feature sometime. So now that that is settled lets move on from the squabbling.
Also - @yorlik, is there a reason you have multiple profiles on this forum?
My thoughts..sorry
The phantom isn't a sophisticated $1300 quad, it is a $500 quad with some expensive toys bolted on.
Why try to solve a symptom, not the cause? Better to spend R&D money on improving the ESCs rather than building a recovery method.
The trend for consumer electronics, including cars, is that the device performs a series of self diagnostics. What we would like to see is the phantom run through a series of checks and report any items outside of the normal parameters.
It's amusing to have someone tell you you are dumb because he's too dumb to understand why last year's Phantom doesn't have next year's features.
Even more amusing when it's someone who understands Phantoms so well that they can write this:
I went thur thru sun last week with NO sat because of such heavy overhead clouds.
I don't need to read your facts to tell my how gps works in my life. sats do go away in clouds, heavy snow, and heavy rain in my world. I am glad this is not so in yours.
If you don't like the product then don't buy it.
My question: "why does firmware not appear to address 1 missing motor?"
Your reply: "If you don't like the product then don't buy it."
Very helpful. Thanks.
About as helpful as your posts eh?
cgarner1
