Why does car SATNAV work, but PV2 struggles ?
Discussion in 'General Discussion' started by Tony Phantom, Sep 26, 2015.
  1. Tony Phantom
    Flying in Italy Aosta, only at some locations high up the Alps no sats are picked up on the Phantom vision 2 plus, but the car satnav works fine ? Any ideas why that is ?
  2. Meta4
    Meta4 Moderator
    Staff Member
    Different antennas.
    Does your P2V+ have the foil mod or is it a V3?
    If not a foil mod should have it picking up lots of sats everywhere.
  3. N017RW
    Palm Beach Co.- FL
    Is the SatNav antenna on the outside of the car?
    If so, The car creates an 'awesome' ground plane and the rule of thumb is the bigger the ground plane the greater the gain.
  4. Tony Phantom
    Car satnav is a small cheapy stuck on window, aerial inside it, unless the usb cable also acts as a aerial.
  5. N017RW
    Palm Beach Co.- FL
    No, the USB is not a factor in reception.
    Can you put the SatNav unit outside the car and compare?
    Not saying it's a 1-to-1 comparison due to yet another different immediate environment but could shed somelight on a contributor.
  6. Tony Phantom
    Version 2. I removed the copper foil mod, because there was evidence of electrical arcing or static discharging. I investigated but no solution.
  7. Meta4
    Meta4 Moderator
    Staff Member
    Without the foil mod, your wifi is emitting interference that disrupts the satnav signals.
    The foil mod fixes this and instantly gives you great satellite reception.
    Easy to do yourself or you can buy one pre-cut like this: Phantom Upgraded GPS Shield
Similar Threads - does car SATNAV Forum Date
SD card in RC does what? Phantom 4 Pro Discussion Jan 2, 2018
Does SD card write speed matter? Standard Nov 30, 2017
DJI Care Refresh does NOT cover repairs, only replacement Phantom 4 Pro Discussion Sep 25, 2017
Does anyone have any FAST MiroSD cards f/s 64gb-128gb? Phantom 4 Pro Discussion Apr 26, 2017
Gimbal does not read Sim card Pro/Adv Discussion Apr 9, 2017
