whoooo hooooo ive got one
Discussion in 'Pro/Adv Discussion' started by Regan9172, Dec 23, 2015.
  1. Regan9172
    hey hey my fellow phantomers
    i have now got one up and running ( took awhile for some reason but Justinj who i bought it off helped me out big style so thanks again justin most appreciated)
    i took out outside (front street)
    neighbour in the background was like...ooo look ufo ahahaha made me smile (it was dark)
    didnt seem to last 5 mins....so spare batter is a must
    i couldnt beleive how sensitive the remote was...yet how sturdy the drone is if left to hover!!
    i was quite nervous when it first took off haha
    QUESTION
    i got some quick release prop guards (the ones where you screw 4 bolts into the drone)
    i screwed them in diagonally and not too tight either
    but when i flipped it up the grey things that the props sit on looked wonky?
    surely they are meant to be level ?
    ive tried to keep them straight but they just dont seem right?
    anyone know what im talking about haha
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If you're referring to the motors, they are all slightly angled by design.
  3. Regan9172
    Collage 2015-12-23 21_06_04.jpg this seems abit too much tho
    All are differe too
    How do you ballance them etc
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That looks okay to me. If you're not sure you installed the screws properly, remove them and reinstall them. Put a bit of pressure on the top of the motor to make sure the base is touching the arm before you insert the screws.
    There is no way to level the motors. They are supposed to be angled.
  5. Regan9172
    that reassures me thanks
    i turned it upside down and rested it on the motors as i installed them
    yeah ive just finished puting them back on lol
    many thanks
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    FYI, if you decide to remove the prop guards at some point, you should use the original motor screws. If you put the long screws in without the prop guards on, you will destroy your motors.
  7. UnrealDrones
    Arlington, VA
    They look fine to me - just make sure the props are on right and you should be good! :)
  8. Regan9172
    yeah i have kept them safe
    theres abit of string that came with the prop guards too ?
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
  10. UnrealDrones
    Arlington, VA
    Nice blacked out Phantom. Is that a custom housing or a wrap?
  11. John Locke
    Yorba Linda, CA
    Msinger, That's not a Phantom 3, look at the battery? It's not wide enough. Wooden props? What is that thing? A clone.
  12. UnrealDrones
    Arlington, VA
    Wooden props are possible :) On a Phantom, that is. You might be right about the battery, though.
  13. TheFlash
    NW Ohio
    Very nice, was thinking carbon fiber wrap, and props
  14. UnrealDrones
    Arlington, VA
    Oooh, good idea!
  15. JKDSensei
    USA
    Looks like a P1
  16. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's not mine. The OP was asking what to do with the string. I was showing what it's used for :)
  17. Regan9172
    still...what is its purpose?
    act a a barrier in between the guards ?
  18. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Correct.
  19. Larry L
    Copperas Cove, Texas
    Personally I have never used prop guards. It is a personal preference. Just a friendly bit of advice for you if you use the string. Keep an eye on it & if it gets any fraying to it, replace. There was a member a while back that was flying & the string broke & wound up getting wrapped in one of the motors. It crashed & tore up his quad pretty bad.
    Good luck & enjoy it.
    dirkclod likes this.
  20. MrMcfly
    Melbourne, FL
    Congrats on your new bird! I didn't string the guards together, just ran the string under each guard. (See pic below)
    It's not nearly as much protection, but better than nothing, and I get the guards off/on quickly.
    You'll quickly see a second battery is good, but a 3rd and 4th is better... Once you get to something you want to
    photograph, it's nice to have all the power you need. This hobby gets expensive quickly... as most of my hobbies are....
    Enjoy!!!!
    [​IMG]
