who is using android with mavic?
Discussion in 'Mavic Discussion' started by Greenenvey, Oct 6, 2016.
  1. Greenenvey
    is anyone else using a android phone when they get the mavic? I'm getting a little worried after reading several threads about 6.0 not working with dji go. anyone else worried about this?
  2. darkneo
    Los Angeles
    I have an Android phone and the DJI Go app has always worked perfectly. I'm currently on Android 7.0 and it works.
  3. dmarlin247
    I have also used my S7edge with no issues but i also read people that were having issues were sometimes corrected by enabling Developer options and switching USB to MTP
    kmaluo likes this.
  4. Alex Baxter
    County Kilkenny, Ireland
    2014 Nexus 6 running Android 7, no problems..
  5. Mako79
    Sydney Australia
    Note 7 android 6.0.1.. Phone battery explodes everytime i use Go app =)
    mikeroycollins, Kilrah, kony and 2 others like this.
  6. tcope
    Salt Lake City, UT
    Odd... everyone above already has the Mavic?
    romi likes this.
  7. sdharris
    South West, England
    Having switched to a Samsung s7 Edge from iPhone recently I am hoping to use android with the Mavic, although I will need to use my old iPhone at times for Autopilot.
    Not strictly related but do any of you long term Android users know how to move the DJI GO media files over to SD Card? I am thinking the video cache and I use it with an Osmo Mobile and it saves it all to the phone memory which is pitifully small?
  8. darkneo
    Los Angeles
    His question was whose using an Android phone "when" they get the Mavic...
    kmaluo likes this.
  9. scottoftheforest
    I was hoping for an easy answer to your Android SD card storage too. I use a 32 gig Note 4 for Osmobile and have to manually move files to the card when doing much in the way of shooting and I've been doing some light poking around looking for a way to default the initial storage to the card, and so far haven't found anything.
    If I do, I'll reply to this thread, and perhaps you would do likewise. Loving the Osmo Mobile (have an Osmo too).
    I'm suddenly hooked on Motion Lapse, though head scratching that it never lets me set up for anything longer than 20 minutes.
    Sent from my SM-N910W8 using PhantomPilots mobile app
  10. sdharris
    South West, England
    I have an answer to your 20 minute time limit as I ran into the same issue. The duration is dependent on the amount of movement between your start point and end point, also helps if you have more than two points. I think they have a minimum 'speed' in order to keep it smooth. Hope that helps.
    And yup, I will reply back here if I find a solution to the storage location.
    Sorry for hijacking the thread everyone.
  11. scottoftheforest
    Beautiful! Thank you. Figured it was related to lack of available memory on the phone internal drive. Much appreciated - love it when it's fixable with know how instead of hardware deficiencies.
  12. m0j0
    Won't be a problem.
  13. Biggle
    I have an S7 Edge and I too thought my phone was OK... until it rebooted mid flight.
  14. tcope
    Salt Lake City, UT
    That _is_ the question... yet many people were commenting that the Go app works just fine on Android.
  15. DroneDad
    Southern California
    To move the files over, go to your Gallery; select the folder where they're currently stored; Select "More" in the top right corner; select "Edit"; select the videos you want to move; select "More" again; then "Move to album". Either create a new one on your SD card or make one before you start this process. That easy. Hope it helps.
Similar Threads - using android mavic Forum Date
Newbi using an android phone, phone got crushed. General Discussion Dec 10, 2017
These are the MINIMUM specs you should fly using android Control (Go, Litchi, etc..) Nov 24, 2017
Android V20 using DJI GO 4 APP Phantom 4 Discussion May 14, 2017
Using custom ROMs on Android devices Phantom 4 Pro Discussion Mar 18, 2017
Is anyone using Litchi with Android 7? Control (Go, Litchi, etc..) Jan 5, 2017
