Where is the barometer / Altitude trouble
Discussion in 'Pro/Adv Discussion' started by FredzMaxxUAV, Nov 24, 2015.
  1. FredzMaxxUAV
    Approved Vendor
    Does anyone know where the barometer is in the Phantom 3? Is it inside the VPS module?
  2. III% Streve
    Its likely on the main board. But just guessing. The VPS system is all about cameras and sonar. It would be poor designing to have the barometer there.
  3. Meta4
    Meta4 Moderator
    Staff Member
    It's in the flight controller on the main board and it's likely that your IMU recalibration will fix it.
  4. FredzMaxxUAV
    Approved Vendor
    So I did a cold IMU calibration. Now after 20 minutes of hovering above grass, with moderate wind, the difference is 2 meters instead of 10. But my old P3P only has a difference of 1 meter. Is this acceptable?
  5. FredzMaxxUAV
    Approved Vendor
    Flew again, it was off again by 10 meters. Is this normal?
    I did a cold IMU calibration once more.
    Current values after the calibration are:
    Gyroscopo: all 0
    Acceleration: 0 0 -1 1
    Compass: -577 -597 1147 1415
    This is when the bird is level.
    Is there anything else I can try. Or is the barometer just not that great on some models? My old P3P was rock solid there...
  6. III% Streve
    Compass MOD value is strangely low, but could be ok
    Acceleration should be at ZERO if its not moving It think, but I dont have mine in front of me to check
  7. alokbhargava
    San Francisco, CA
    GPS is the main sensor to get the height estimations. VPS system too can calculate heights but it is effective only up to about 3 meters and provided ground surface is good. There are many restrictions on ground surface. It has advantageous only in case one is unable to get enough satellites locked to get proper location.
  8. FredzMaxxUAV
    Approved Vendor
    I thought the barometer, not GPS or VPS, was mainly used for altitude. Am I mistaken?
  9. III% Streve
    GPS supplements the barometer. It is not primary. VPS takes over below 3 meters
    Oso likes this.
  10. FredzMaxxUAV
    Approved Vendor
    What would be good values?
  11. III% Streve
    Mine, while in the house, are almost exactly the same. Personally, I dont like a compass MOD value outside of 1500+/- 40. But the real answer is far more open. I think the sweet spot for my P3 is somewhat based on my location. Leading to a thought that everywhere in the world will have different "sweet spots" and likely are going to vary also because all compasses cant be perfectly identical
  12. Oso
    Oso
    Western US
    This is what I was told by one of the mods (now gone) when I first joined, so this is what I have posted numerous times when asked.
    Gyroscope Mod should be around 0.00
    Acceleration Mod should be around 1.00
    Compass Mod 1400-1600
    JoBe likes this.
  13. N017RW
    Palm Beach Co.- FL
    Unless there has been a documented change... GPS has never been used for altitude in the Phantom series.
    The Phantom only need know it's height relative to take off thus a barometer is fine.
    Remember the price-point for this flying camera is very low.
    DJI's top-tier FC is more than the P3s in total.
  14. FCPhantom
    Finland
    I asked it from DJI and they said it is barometer's feature. The barometer has 2cm/s of error.
    If the flight time is 25min = 1500s, then the error can accumulate approximately to 30m = 2cm/s * 1500s
  15. Mako79
    Sydney Australia
    Make sure the phantom has been off for an hour or so. Do the calibration at night when its cooler. Do the IMU calibration the moment you turn on the Phantom. The cooler the phantom, the more accurate the barometer will be. And there is no need to place phantom in the fridge.
  16. Mad_angler1
    UK
    baro is located on the bottom of the FC daughter board, you can see it from the battery bay located next to the SD card :)
  17. FredzMaxxUAV
    Approved Vendor
    #17 FredzMaxxUAV, Nov 26, 2015
Similar Threads - Where barometer Altitude Forum Date
Waterproofing with Corrosion-X / where is the barometer? General Discussion Apr 25, 2014
Tell me where to go (gently please) Photos and Video Yesterday at 4:50 PM
Where did DJI Go go ? Control (Go, Litchi, etc..) Jan 1, 2018
Hawks everywhere! General Discussion Dec 30, 2017
Where is the flight data stored? (a) P4P (b) micro SD (c) RC or (e) Tablet? Phantom 4 Pro Discussion Dec 23, 2017
