What sequence to set in adobe pro?
Discussion in 'Pro/Adv Discussion' started by jake88, Apr 29, 2016.
  1. jake88
    Hi guys just got adobe premier pro 2015 its asking me what sequence do i use??? I have no idea ive looked thru them and the only 4k i can see is from the red cam lol....yes im editing in 4k and my pc is more then capable..thanks in advance
  2. 4wd
    4wd
    North York Moors
    It is pretty boggling at first.
    There's a huge amount of help online especially youtube - however your question is fairly easy - just cancel those initial small screens, import your clip then you can create a new sequence from the clip.
    After a while you can build up some settings to select e.g. 1080p @ 30/60fps or 4K
    Make a name for your project though so it can be saved and opened later as you often want to try something different after rendering (another minefield ;) )
Similar Threads - sequence set adobe Forum Date
Adobe premiere sequence settings.. General Discussion Apr 29, 2016
Gopro Sequence Settings in Premiere General Discussion Oct 8, 2013
strange LED light sequence P4P Phantom 4 Pro Help Jun 25, 2017
Sequence for powering up / connection Phantom 4 Discussion Mar 2, 2017
Standard Start Up Sequence? Phantom 3 Help Feb 5, 2017
