What is the problem with my recorded video? How can I fix it
Discussion in 'Phantom 2 Vision + Discussion' started by vjdave, Jun 1, 2014.
  1. vjdave
    http://youtu.be/bS3ggZiodVw
    What is this problem with my video and how can I fix it? This is starting to ruin my videos leaving me with not much good footage to edit with? Interference?
  2. skyhighdiver
    South Dakota
    Re: What is the problem with my recorded video? How can I fi
    I get a lot of this as well my props are balances and still
    worse all the way up and 45 or any forward movement backwards is better
    even in a hover its bad atti and gps
  3. vjdave
    Well I won't be able to shoot in lower light conditions since I can't control the brightness of the sun :lol: . I have never attempted 720p/60 yet (Always have done 1080p/30) so if that is the solution I will try it!
    Thank You!
  4. vjdave
    So now I can't fly in rain or on sunny days? This is leaving very few weather conditions left to fly in :lol: Guess I will only fly on cloudy days with no rain. Yeah...if I can't fly on sunny days then I might as well sell it.
  5. 4wd
    4wd
    North York Moors
    I don't see rolling shutter in that clip, it's jello and the cause is vibration.
    Balancing props would be first thing to look into.
    Using 60fps at 720p will probably reduce it a lot too.
    Worth checking everything is in order with rubber isolation balls, I have heard of some wearing through so the camera was resting on the retaining pins.
  6. Phantom_Menace66
    Perth, Western Australia
    I notice the camera is facing toward the sun, I have been told that it is an anomaly caused by a combination of sunlight on the lens & the props spinning & casting shadows rapidly on the lens of the camera. Try to video with the sun anywhere except straight ahead, see if this helps.
Similar Threads - problem recorded video Forum Date
Advanced Problem, lines in the screen and video recorded Phantom 3 Help Sep 14, 2016
Phantom 4 controller charging problem Phantom 4 Discussion Tuesday at 8:48 AM
Moire problems noticed in my P3P footage Pro/Adv Discussion Monday at 8:28 PM
Huge problems after update of firmware Phantom 4 Help Monday at 3:36 PM
i phone mini 4 problem. Phantom 4 Pro Discussion Monday at 8:14 AM
