  1. Hipstery
    Title says it all
    It is still the 500m like the P3 or has it been increased/decreased ? Please tell me is the same or higher!
    Thank you
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes, it's still 500m.
  3. PaulJohn
    Still 500m on the DJI GO app, but as far as your signal reaches and battery will allow in Litchi
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You cannot fly higher than 500m in Litchi either. DJI has baked that limitation into the Phantom firmware.
  5. PaulJohn
    [​IMG]
    Haven't personally had a chance to test it, but multiple people have confirmed its possible. I may as well be wrong.
    When has this firmware limitation began?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That comment is from 10/12/2015 :)
    That has always been the limitation. There was a bug in one of the first firmware versions that allowed that limit to be bypassed by doing some unusual things. It was patched a while ago though.
    PaulJohn likes this.
  7. PaulJohn
    I'm forgetting 6 months is an eternity in our digital age Oh well, at least we won't be tempted to break the rules!
  8. Meta4
    Meta4 Moderator
    Staff Member
    You might need to brush up on what the rules are where you fly.
  9. Farmer
    Northland, New Zealand
    You guys must mean FEET?☺
  10. HTX
    HTX
    No they meant 500 meters
    Ramphex likes this.
  11. Ramphex
    Pennsylvania
    500m - 1640ft.
  12. CactusJackSlade
    Still not enough.... 500m AGL yes.... 500m above take off is not enough in many of my flights! One reason I hang onto one of my P2's and another NAZA controlled bird...
  13. phantom13flyer
    When litchi first came out it didn't have any limits but that was changed a couple weeks later when Dji hard coded it into their software.
  14. dewster
    It's boring above 400 feet.
    jsposito and peterepeat69 like this.
  15. johnny85
    I agree it should be 500m agl not above take off.
  16. sar104
    Los Alamos, NM.
    That would be nice, but difficult to implement. There is currently no way to ensure that local ground elevation data are available to the aircraft, or even to the controller, without a guaranteed internet connection.
  17. neven
    Zagreb, Croatia, Europe
    I wouldn't mind 100m AGL limit
  18. Cale262
    Alberta/Arizona
    You can always set your own equipment to a 100m limit.
  19. John Locke
    Yorba Linda, CA
    I think what neven means is 100m AGL is OK including when you're climbing a mountain 3000' higher than takeoff point. I'd be OK with 100m AGL too if it was unlimited above takeoff point. 1640' from takeoff isn't enough sometimes, even if I'm only 100' AGL all the time. However, sensors can't sense ground level 100m away so there's no way to implement unless the craft always had an internet connection. Maybe someday.
  20. neven
    ^ what he said :)
    I don't think it is too complicated to introduce AGL to Phantom. Google has ASL for most if not all GPS coordinates so downloading map of area to your bird or tablet for offline use is a possible. That way Phantom will be aware of AGL at all times.
    Slim.Slamma likes this.
Similar Threads - max height Phantom Forum Date
DJI Phantom 3 Standard Max Altitude Test! Secret to fly 500 meter height ! General Discussion Jul 3, 2017
GO not reporting correct MAX height... Control (Go, Litchi, etc..) Friday at 5:29 PM
Max height Standard/4k Discussion Jun 3, 2017
What is the Max Height Allowed in Your Country? Rules and Regulations Apr 9, 2017
Guarda "Max height test" su YouTube Standard/4k Discussion Mar 7, 2017
