What is the function of micro-usb connector?
Discussion in 'Pro/Adv Discussion' started by Omegas, Jan 13, 2016.
Tags:
  1. Omegas
    1. What is the function of micro-usb connector on P3P rc-controller?
    2. There is any way to simultaneously use and charging (from external powerbank) pad/phone?
  2. HCAV Mick
    West Yorkshire
    I have the P3A, the manual states: it's a reserved port, maybe different on the P3P model?
  3. rockydog
    London UK
    The micro usb is a reserved port and serves no function for pilots.........you can't use it for charging.
  4. Omegas
    What if use that Y-cable?
    How i can check, that USB in P3P port doesn`t have power-line?
  5. happydays
    Warrenpoint, Ireland
    On the original phantoms (1,2) it was used for connecting to a pc, for updating the software for example.
    On the P3 range, it is used to access the internal SD card that stores all of the flight logs in .DAT format. If you crash, this is the information that DJI will interrogate to ascertain how / why the craft crashed.
    Numone likes this.
  6. Omegas
    On RC controller?! No...
Similar Threads - function micro usb Forum Date
Will the P4P get the Spark Panoramic Function? Phantom 4 Pro Discussion Aug 2, 2017
Standard Can a bad roll motor cause gimbal to malfunction? Phantom 3 Help Jul 27, 2017
RTH function Phantom 4 Pro Help Jul 19, 2017
Standard P3S Crash into Ocean- possible hardware malfunction Phantom 3 Help Jul 9, 2017
Waypoint Function Does Not Work for P4P+ Phantom 4 Pro Discussion Jun 18, 2017
