What is the best option to film a running train by PV2+?
Discussion in 'Phantom 2 Vision + Discussion' started by AAC, Oct 2, 2014.
  1. AAC
    AAC
    I want to follow a running train for 2 km and do aerial filming over it. The train running along the shorelines will make some turns. Therefore, if pV2+ following the train, loss of sight will happen.
    Ground Station Waypoints can be one of the easy options but the flying speed is fixed in Slow/Mid/Fast, I'm not sure if it will follow the train in constant speed. Course Lock mode looks good but will lost control or camera signal when train turns to other side of the forest.
    Any suggestion ?
    Thanks.
  2. ilovecoffee
    Will the train be going slow enough for you to keep up with it?
    If you use Ground Station (and you'd have to use my modded one to go over 2km), you'll still lose time when it reaches each waypoint, even with my mod of removing those pauses, since it has to decelerate to each waypoint.
    Something to keep in mind. If you lose sight, seems like your only bet is GS.
Similar Threads - best option film Forum Date
Hardware Pc Missing - Best Option to Repair? Phantom 4 Pro Help Oct 28, 2017
Blending Jump Cuts, Seeking Best Options After 4K60 Video Glitch Removal Phantom 4 Pro Discussion Jun 22, 2017
What are the best options in 2017 for an ND filter for P2V+? Phantom 2 Vision + Discussion Jun 21, 2017
BEST CAMERA OPTIONS Photography and Film Mar 30, 2017
Best Purchase option for P4 Pro Phantom 4 Pro Discussion Feb 2, 2017
