I'm been racking my brain on trying to get the motor apart to change the bearings after taking out the fastening ring. It will not come apart. Am I missing something???
I had the same issue, the copper winding wire (if thats what u call it) was jamming and I had to prise it apart with a screw driver. I managed to push the wire back with out breaking it so I am hoping it will be ok.
weven said:Now i'm worried.
Surely the windings are stationery, the outside is rotating, so no forces :?:
After putting back it together it feels the same as all the others. I had replaced all the bearings after it went swimming.
Which it does poorly
I thought the same thing, but it's simply the magnetic field within the motor that is causing your resistance to pulling the motor apart.FangsCPO said:I'm been racking my brain on trying to get the motor apart to change the bearings after taking out the fastening ring. It will not come apart. Am I missing something???
Maveriksam said:I thought the same thing, but it's simply the magnetic field within the motor that is causing your resistance to pulling the motor apart.FangsCPO said:I'm been racking my brain on trying to get the motor apart to change the bearings after taking out the fastening ring. It will not come apart. Am I missing something???
Don't use anything sharp or metallic if you can but you just need to persevere with something solid and prise the outer housing from the stator inside. Once they are apart, be careful when putting them back together. The magnets have quite a strong pull and you could trap your skin when it closes together.
FangsCPO said:Maveriksam said:I thought the same thing, but it's simply the magnetic field within the motor that is causing your resistance to pulling the motor apart.FangsCPO said:I'm been racking my brain on trying to get the motor apart to change the bearings after taking out the fastening ring. It will not come apart. Am I missing something???
Good to know. I may just go with fresh motors than.
I still can't get this apart. That is one strong *** magnet, are you sure there is nothing else to remove to free up the motor casing????
weven said:Fangs
Read my post.
I could not pull it apart and prised it open with screw driver and one copper wire was jamming it. I would guess from a previous impact. The other three came apart, but they do require a firm pull and rotate.
Cheers
